8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert),
94
Mod | | | Forums66 Topics128,052 Posts1,055,716 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#97270 09/21/2006 12:17 AM | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | I have a 61 1/2 ton that was changed for a generator to an alternator before I purchased it. Now I am having trouble with the external regulator. I have a newer alternator from an 81 chevy. Is changing from an external regulator to an alternator with an internal regulator difficult? I know hardly anything about electrical work so please keep it simple. :confused: | | |
#97271 09/21/2006 12:57 AM | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | It's really not hard to do. Get rid of the old regulator, and the 3 or 4 wires that are with it. Run a 10# gauge wire from the starter sol. post where the + battery cable is hooked up... up to the battery post on the new alt. There should be a flat 2 wire plug on the alt, with a#1 and a #2 mark buy it, Hook up the #2 wire to the same post on the back of the alt. that you put that heavy wire from the starter on. The #1 wire should go to the acc. side fo your ign. switch. Thats it.If you have any questions, call me at 319-752-1036 ,Larry | | |
#97272 09/21/2006 1:32 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Sounds easy to do. My only question would be how would #1 wire excite the alternator if the key switch wasn't turned to 'accessory'. :confused:
Stuart | | |
#97273 09/21/2006 1:47 AM | Joined: Apr 2006 Posts: 21 New Guy | | New Guy Joined: Apr 2006 Posts: 21 | 61Apache, I've found a website that has great electrical tech tips. Its called: http://www.madelectrical.com/electrical-tech.shtml It has good overall reading, but the article called CHEVY Main Electrical Power System is a must read for your situation. Best of luck, Dave | | |
#97274 09/21/2006 2:24 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Stuart, Stuart, Stuart-
The accessory position is also enabled in the run position, but not conversely. Putting the wire on the accessory position makes sure that the engine doesn't run on from alternator power when you switch it off. | | |
#97275 09/21/2006 2:37 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Sheesh, must have been absent that day. :o Good job hot rod, very succinct post. Stu--pid | | |
#97276 09/21/2006 9:39 PM | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | Thanks so much for all the help. I will rewire this weekend. If I get stuck Larry I will give you a call. This site is so great.
Kim | | |
#97277 09/21/2006 10:24 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | 61apache,
I have a thought...it might be wrong, but I'll mention it anyway.
With your old externally regulated system, #4 on the regulator should have been the feed from the key and charge indicator light, if you had one.
If you hooked your new #1 wire to this wire, you wouldn't have to dig under the dash, plus you would have the idiot light function as before.
This light would offer the resistance necessary to stop any run-on.
Your old alternator should have had a large power lead that could just be connected to the new alternator.
Your sensing wire...#2 could wrap around as hot rod indicated and attach to the power lug.
Sure hope this is right!!
Stuart | | |
#97278 09/22/2006 1:13 AM | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | Thanks Stuart, I was wondering If a good underhood connection point for the #1 wire existed. Thanks for your help. | | |
#97279 09/24/2006 11:09 PM | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | Thanks guys, everything seems to have gone together without a hitch.  | | |
