0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#971148 09/12/2013 11:35 AM
Any suggestions on removing rubber door seal?
joes1952 #971150 09/12/2013 11:43 AM
An exacto knife if it's glued and some years may have small mounting 't' pins that hold it in place. My replacements had them about every 4 in" (they lined up with the pre-existing holes) but I still used some 3M black to set them.
Give me ambiguity
or give me something else
joes1952 #971237 09/12/2013 7:41 PM
the door seals (weather stripping) on my 52 were glued on.
joes1952 #972703 09/19/2013 8:51 AM
A guy (restorer) from Oregon cam Down to Sac last June. He said the reason my doors don't close right might be the weather strip install...and I can see that. It looks to be upside down and has a pointed edge showing which seems to prevent the door from closing all the way. Sound right ? I have not seen any cross sectional pics of how the should be installed...I suppose it's just intuitive...and hopefully not difficult..
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
joes1952 #972717 09/19/2013 9:31 AM
joes1952 #972724 09/19/2013 10:05 AM
It could well be installed inside out... I almost did that when starting to put on mine.
Give me ambiguity
joes1952 #972728 09/19/2013 10:10 AM
That's what I was trying to say...just didn't use the right words...thanks... Should not be too hard a job to replace ?
Mark
1949 Chevy 1/2-Ton
Lucielle
joes1952 #972733 09/19/2013 10:17 AM
I installed mine the right way and still never got the doors flush. Hoping over time it will crush it a bit more for a better fit.
joes1952 #972735 09/19/2013 10:28 AM
Is it better than it was ?
Nice trucks, both.. I think I may have copied your bed rail design... Mine is cedar (that's what they mill around here) and looks better as it darkens with age...
Mark
1949 Chevy 1/2-Ton
Lucielle
joes1952 #972809 09/19/2013 3:27 PM
this if my 52 panel. The pic is of the right door. It is installed the way I'm holding the piece. Just looking at the pic with it installed on the door its really hard to tell.
Hope this helps.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0216.jpg
joes1952 #972824 09/19/2013 4:39 PM
Thanks Chip... Looks correct to me too. The guy who put mine it has it turned 90 degrees clock wise so that sharp edge sticks way our than hits the door frame inside... I think that prevents it from closing to some degree...
Mark
1949 Chevy 1/2-Ton
Lucielle
joes1952 #973100 09/20/2013 1:59 PM
Jerry Kassis from Oregon... Dr J's Restoration Rx... just did a video on installing door weather stripping. Great guy and knows his stuff... Here's the link
www.youtube.com/watch?v=MuuZpec4rXo&feature=youtu.be
Mark
1949 Chevy 1/2-Ton
Lucielle
Dogface #973926 09/23/2013 9:02 PM
great how to
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
joes1952 #973938 09/23/2013 9:43 PM
I installed mine same as Alvin
Looks like the guy in the video turned his 90 degrees
I tried it that way and my door would not close.
Moderated by  ndkid275, Phak1
