Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 35 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#972075 09/16/2013 6:09 PM
Conducted compression check on 1941 216 chevy. All of the numbers were between 90 an 105. Should i be concerned? Is it time for new rings?
eyell #972086 09/16/2013 7:01 PM
Actually, those numbers look OK to me. I don't think the 1941 216 has a lot of compression any way. Is the motor smoking? If so is it smoking during acceleration? Might be rings. Under deceleration? Might be valve guides. If it is not smoking and it has good oil pressure and no expensive sounds then it is probably just fine. It will only make about 80 to 85 Horse power when it is all new so that is what it is. Some of these motors will last a good long time if not abused and maintained. I had one in a 1950 1/2 ton I drove daily to work and home for 7 years. Leaked but ran just fine. I drove around with a case of EP recycled oil in the back and "checked the fuel and filled the oil" on a regular schedule. I miss that truck.
Steve H
