2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#97114 09/10/2006 5:24 PM
Hi Folks,
I'm looking for a wiring harness for my 41 truck. I found that the old wiring is in need of replacement. I need to find an outfit that sells new harnesses for a REASONABLE price. Need one that is marked well for installation.
Jeff
#97115 09/10/2006 5:37 PM
Check with The Filling Station they show wiring harnesses on thier online catalog.
I resently completely rewired a 1954 corvett the harness was purchased from an online parts house. The harness was made by Lectric Limited (708)563-0400 Justice Il. It had cloth covering and was easy to install. It also came with a 3'x 2.5' laminated schematic. $600.00 was kinda pricey but everything on a vet is.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#97116 09/10/2006 6:46 PM
I checked and they want $500 for a harness. I was looking for on at half that price. Is this unrealistic?
Jeff
#97117 09/10/2006 9:07 PM
Ex Hall Monitor
Ex Hall Monitor
Depends on what you want. I paid over $400 almost two years ago for a restoration harness from YNZ\'s . Excellent marking, instructions and customer support. There are cheaper harnesses but I've never bought one so I don't know the level of support that comes with them. It was a bit of sticker shock to me too but I'm happy with my purchase and will buy from them again if the need arises.
#97118 09/10/2006 9:24 PM
I bought mine from American classic truck parts a year or two ago. I just installed it. It seems like it will work just fine. Current price is $180.00
The crew that works on the \'42 --Sara, Hannah and Abby
#97119 09/12/2006 3:33 PM
I put a stock 12 volt replacement harness into my 39, the only thing i dont like that much is it doesnt have any fuses on it... price was around $150 or so... well marked and easy to install... no problems with it 5 years later...
Another quality post.
Real Trucks Rattle
#97120 09/12/2006 7:05 PM
Made my own using info from the web and wire from a friend in the business, works fine, cost just about $0.00
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#97121 09/12/2006 8:27 PM
Kip's 41 must have lots of time on his hands...
BUT, if one had the gumption, they could acquire a wiring harness, lay it out on a board and map it, then it would be fairly easy to build them... anyone want to go into business? I've seen this type of board at the USMC Rebuild Depot.. it would be fairly easy to make one; each circuit is mapped to the board, with the wire size and length, connectors ect marked on the board. They have a bunch of nails and it's "follow the little line", bundle them and voila.
look at this web site too.. lots of good info
http://www.madelectrical.com/electrical-tech.shtml
Real Trucks Rattle
#97122 09/12/2006 10:12 PM
If you are wanting origional look you will pay a bit more. If not then go with the tape wraped wiring It will serve the same function.
#97123 09/14/2006 4:42 PM
Junior Member
Junior Member
I purchased the entire harness for my '41 Chevy from Jim Carter's truck parts. It has not been installed yet...still studying up on how to do it. If it works, it was worth the $150.00. If anyone knows the easiest way to install one, please let us know.
#97124 09/15/2006 1:56 AM
I’m telling you guys it was not all that difficult.
I had the dash out of the truck and attached all of the wires to the various items on the back of the dash. Head light switch, ignition switch, amp gauge, etc. I coiled up the rest of the wire and suspended it to the dash, then installed the dash. From there most of the wires go out through a large, about 1’ hole in the upper driver’s side of the firewall. Once you get past the dash wiring its pretty straight forward
#97125 09/15/2006 3:38 AM
I'm with Kip's41.
I've been rewiring my '46 as I go, and there really isn't anything to it.
As long as you know how to use pliers to crimp on ends, use heat shrink tubing and solder, you're golden. All you need is time.
Total cost of mine so far: $35.00. And that's mostly ring terminals and heatshrink.
#97126 09/15/2006 3:07 PM
Ex Hall Monitor
Ex Hall Monitor
Hey Brendan, who do you go to with a warranty claim if something screws up? :p grin
#97127 09/18/2006 2:27 PM
Quote
It NEVER screws up! grin
#97128 09/18/2006 4:44 PM
BrendanM, on you truck where is splice 3d located and is it a ground or hot? lolol The schematic shows a black wire with a red tracer, is it a red tracer or maroon?
#97129 09/22/2006 10:01 PM
On mine there are no splices. All wires are joined with crimp on ends at the terminal. The wires are mostly all blue THHN with permanent wire numbers on both ends. Not stock, just a little better. There are so few of them it should never be a problum to trace
#97130 09/23/2006 12:41 AM
Baldbaron,
I am in the process of installing Jim Carter's $180.00 harness. The price of copper has driven the cost of this harness up by $40.00 this year.
The harness is wrapped in a black weave that makes it look "Ol' Timey" and sorta origianl. It is much better than the 10 feet of electrical tape wrapped original harness I removed.
So far, it has been pretty easy to install and comes with turn signal wires built in to the main harness.
I know $180.00 is not cheap, but I know if I try to make my own, nothing will work...ever.
Gwen...Just have at it! It is easy...have a shop manual with the diagram handy and it won't take you long at all.
