1 members (KEVINSKI),
160
Mod | | | Forums66 Topics128,108 Posts1,056,228 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I have my seats out of my 1950 3600. The springs and frame are in great shape. I want to recover them and would attempt it myself, however, there seem to be only a few basic colors. I'm considering just bringing them to an upholstery shop and going with something that will have a bit more support and possibly even two tone to match the interior/exterior color.
So, my questions are...
1) I use an upholstery shop, what is a fair price to pay?? 2) Are there any vendors that offer a color selection for a seat cover kit I can do myself?
thanks.
UPDATED>.. I round a local shop and will have them recover the seats.
Another question please. What is the most economical heat and sound deadener to use? There are several on line and wanted to know how much to do the inside of the cab. What are you folks doing? Just the floors or are you doing the roof and back area behind the seat too?
Thanks.
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | For the cheapest sound deadener go to lowes or home depot and get a roll of the foil backed insulation. Its about a 1/4" thick with foil on both sides. You can cut it to fit and glue it in place. Not as fancy as dynamat but much, much cheaper. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | That foil backed insulation was called Reflectix at our local HD Dave. Let me know if your interested I'd split a roll with you for my new OT project.
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Yea Rick. I'd be interested. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I don't know if you guys will really need to split a roll. It's pretty cheap, and I used an entire 50' roll putting 2 layers everywhere in the cab of my 46. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | available too at most swap meets, around $25 or so a roll. ( works good for hot water heater insulation) | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The stuff I get is meant for exactly that, hot water heater installation, but is a very cost-effective solution for vintage vehicles. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I am about at the same stage. I have investigated sound deadener until I am blue in the face. I am going to go with Dynamat no name. Basically, Dynamat without the logo. Very inexpensive on Ebay.
I plan on doing rear cab (lower) panel, floor behind seat/under tank, firewall, roof, inside doors. I also undercoated the cab with 3M Body Shutz (acts as sound deadener as well). The main part of floor will be painted and covered by rubber floor mat (to retain original appearance.
Of course, I have to paint the interior before applying the sound deadener...almost to that point.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Sounds like a great idea. What kind of glue? Steve | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I followed a similar path when it came to do mine,I bought generic sound deadener self adhesive pads from my local paint shop,I then covered that with the foil backed heat insulation everywhere,firewall,roof and behind the seat. I used 3M carpet contact adhesive for the foil and so far it's holding up well,including the roof,despite some unusually high and prolonged(80+) summer temps here this year. I'm pleased with the results,I can hold a normal conversation at 60+mph and without being cooked by heat transferal.... Best of all(and being a full card carrying thrifty Scot)it didn't cost a whole lot either!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Sounds like a great idea. What kind of glue? Steve I always use clear silicone. It works great and bonds very well. You just need lots of ventilation and to let the cab air out, but it works great and is inexpensive. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Thought I would post a picture of my recoverd seat. Came out great! I have white interior and windsor blue on the exterior so wanted something that would match both. I also wanted thicker material then the thin stuff that's sold with the kits out there along with a bit more 'padding'... seat | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 500 internal server error..... me or your??? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | 500 internal server error..... me or your??? You. I was able to view it. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I get the same error as well.
Anyone know the cause? | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Let me try the pic again. seat The error was most likely on my end trying to upload a pic from junkie work computer... This should be better. | | |
