0 members (),
81
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 20 New Guy | | New Guy Joined: Jan 2009 Posts: 20 | I have a 54 GMC I am restoring and in checking the engine I find the block stamped with the number # 6107328 which is a 1954 248 GMC engine, however on the area by the distributor where the engine number usually is all that is stamped on it is 248, is that a factory rebuild or what? Thanks for any in information.
" Hard Times Don't Last , Strong People Do."
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If the only thing on the pad behind the dizzy is the 3 digits I'd guess its a rebuilt engine. The original # always began with the engine size but had other info after the 248...
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Factory replacement GMC engines came with only the displacement stamped on the pad. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | steve, 6107328 is a block casting code that is actually cast into the block. That code indicates a 1953/54 248 GMC block. The "engine ID or serial number" is pressed into the block after casting. It shows the engine size plus a serial number if the engine was installed in the truck at the factory; or, that pressed-in code is just the engine size if it was a factory replacement engine/block (as described by others in posts above). | | |
