3 members (Hotrod Lincoln, BC59, 1 invisible), 134 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#969456 09/05/2013 8:12 AM
I have a 54 GMC I am restoring and in checking the engine I find the block stamped with the number # 6107328 which is a 1954 248 GMC engine, however on the area by the distributor where the engine number usually is all that is stamped on it is 248, is that a factory rebuild or what? Thanks for any in information.
" Hard Times Don't Last , Strong People Do."
If the only thing on the pad behind the dizzy is the 3 digits I'd guess its a rebuilt engine. The original # always began with the engine size but had other info after the 248...
Give me ambiguity
or give me something else
Factory replacement GMC engines came with only the displacement stamped on the pad.
steve,
6107328 is a block casting code that is actually cast into the block. That code indicates a 1953/54 248 GMC block.
The "engine ID or serial number" is pressed into the block after casting. It shows the engine size plus a serial number if the engine was installed in the truck at the factory; or, that pressed-in code is just the engine size if it was a factory replacement engine/block (as described by others in posts above).
