6 members (Otto Skorzeny, Bwana-Jim, J Lucas, Hotrod Lincoln, Jon G, MikeE), 96 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#968937 09/03/2013 10:27 AM
Everything I read says fill with SAE 10 oil when cleaning and reassembling No one has it. Is it ok to use something else?
cassie #968938 09/03/2013 10:31 AM
I use engine oil.
My Blog
cassie #968942 09/03/2013 10:49 AM
SAE viscosity (resistance to flow) is a reference for temperature. 10 happens to be -4deg to 50 deg. The W on some labelng is for winter service for a particular viscosity (tested). You should be fine using SAE 20 you are looking for oil that will flow so the bigger the number the slower the flow. Basically all motor oils are a base and then additive packages are selected for particular applications. You could spend years studying this and the science of oil blends. Find some 20 that is what I used.
cassie #968995 09/03/2013 4:25 PM
Thanks. I will try to find 20w, if not I will use the engine oil.
cassie #969230 09/04/2013 11:16 AM
Any oil will work, you are only using a small amount per lifter, grab what ever you have on hand or are going to use once the engine is back together.
Joe
