| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | does anyone remove and or modify the inner cab. i have dents on the bottom half of my cab and noticed that there is a second skin per-say on the cab. it looks as if someone tried to bend the dent out and only accomplished to bend the corner hole thing. i would like to try my hand at repairing the dents. thanks. pics are always a bonus. ill try to get pics tomorrow. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Inner cab of what? But yes there is an inner and outer skin that is spot welded together. I choose to pull those dents out rather than 'open that can up' so I could swing a hammer... unless rust is involved.
| | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Sorry its a 48 chevy 4400. The dents are on the low sides in the corners and a few creases on the back of the cab in the middle. No rust but I don't know how to pop them back out from the outside | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | These are general suggestions that you can find PLENTY of info on using that software program... ohhh WHAT was it?????
Oh Yeah...........Google
1. You can drill holes and use a slide hammer. 2. you can use a mig welder and weld nail heads to the area and then useing vice grips pull out while gently hammering around the edges of the dent, working it a little at a time. 3. You can use a special dent pulling welder that spots the stud/nail for you and THEN work it like #2
Go to YouTube and watch some vid's on the subject. There are good ones and bad ones so watch enough to tell the difference then have at it!
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | 47/48 trucks have a substantial inside liner that was removed in 1949 when the gas tank relocated inside. I would not recommend removing it or portions of it but follow some of the suggestions above. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | I don't want to go buy a bunch of tools to fix the dents. If it was removed in 49 why is it a big deal if it comes out or not? Is it a pain to reinstall super flimsy? I just think it would be easier to tap it out with a hammer rather than drilling unnecessary holes. Just curious. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a section of the inner panel behind the seat was left off [and re-enforced differently] with the tank design change, but overall the cab inner and outer were built up a step at a time with a lot of spot welds, a "cab within a cab", the double wall design is what gives it the necessary structural stability .... if you want to cut away the section behind the seat, fly at it, if you think you'll be able to reach all the repair areas that way - have you ever tried hammering out dents from the back? mostly not simple, and if you're willing to cut away interior panels, you must have a welder to put them back? why not just use the welder and nails to pull the dents as said above? and one cheap slide hammer is useful for a variety of jobs without being a "bunch of tools"
Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Well since your curious.... What your experiencing is inexperience and whats been offered is experience. Sometimes you don't really get it till you DO IT... Some people ask and decide to go with experience and others do it their way and some of those folks do really nice work and some of them sell unfinished projects for 1/4 what they think it was worth when they started... I've personally tried some of the "My Way" techniques but experience taught me to start by 'listening' and I got finished faster!
| | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | Its more of an assumption that it would be simpler to bang them out from the inside. I don't have a stupendous amount of body work and I appreciate the help. Some are dent others are creases so I need to figure out which technique works best. What size nails are we talking about to weld on the body? | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | The 47 and 48 cab had the extra center support that runs from just below the rear glass to the floor to provide support for the center cab support at the rear. In 49 they went to the shackle cab support, eliminating the need for the center cab support. Coincidentally, it made room for the gas tank. If it were mine, I wouldn't touch the center cab support.
