5 members (1955 1 Series, mason86, Wayne67vert, Peggy M, Hotrod Lincoln), 85 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#96787 08/25/2006 4:45 PM
Installing sealed beam headlights in my 1938 HC 1/2 ton. Using "homemade" wiring harness in entire truck. What is the terminal orientation on the sealed beam bulbs ? I don't have anything here to go by. As you look at the terminals on the headlight, which is ground?..low-beam?...Hi-beam??? any help would be appreciated! Tnx
"You are only young once, but you can ALWAYS be immature!"
1938 Chevrolet H/C 1/2-Ton
Diagram Courtesy of Oehm Jr.:
http://oehmjr46.tripod.com/id45.html
#96789 08/26/2006 12:13 PM
Thanks for your help! You are a gentleman and scholar. (dang few of us left!)
