| | | Forums66 Topics128,049 Posts1,055,652 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96787 08/25/2006 4:45 PM | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Installing sealed beam headlights in my 1938 HC 1/2 ton. Using "homemade" wiring harness in entire truck. What is the terminal orientation on the sealed beam bulbs ? I don't have anything here to go by. As you look at the terminals on the headlight, which is ground?..low-beam?...Hi-beam??? any help would be appreciated! Tnx | | |
#96788 08/25/2006 7:37 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | | | |
#96789 08/26/2006 12:13 PM | Joined: Oct 2005 Posts: 31 Member | | Member Joined: Oct 2005 Posts: 31 | Thanks for your help! You are a gentleman and scholar. (dang few of us left!) | | |
