0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#967622 08/28/2013 4:00 PM
Curious where you guys source new pistons for the 216. Aluminum if possible. I see that EGGE is one...are there others?
stove51 #967625 08/28/2013 4:19 PM
I got mine from Egge. Best price/availability that I could find when placing the order. As fate would have it, they were backordered and took forever to get. (or, was that the crank bearing shells?).
stove51 #967634 08/28/2013 4:43 PM
Ex Hall Monitor
Ex Hall Monitor
I got mine from Kanter who buys them from EGGE I found out when I opened the box.
stove51 #967656 08/28/2013 6:01 PM
Ok. Thanks guys. I'm getting block bored out and the engine shop hasn't ordered pistons yet. I was gonna light a fire under his keester. And I see you can order them oversized in multiple sizes too on egge. So lots of options.
Time to get my machine shop firing on all pistons...so to speak smile
stove51 #967676 08/28/2013 7:32 PM
I think they are a newer style with thinner rings, at least mine were. Since I am kind of resistant to change (progress) I was quite shocked!
1951 1 Ton Completed
stove51 #968051 08/30/2013 3:25 PM
A lot of machinests (old timers) will not bore a motor 'till he has the pistons on hand and will then bore each hole to suit a certain piston (at least the way they used to do it)--only exception I had seen was if you were ordering TRW pistons- the machinests trusted TRW's quality control enough to proceed without having them in hand. I checked a set of six TRWs for a 261 once, and found less than one thousandt inch difference from biggest to smallest piston--not bad!
edski #968199 08/31/2013 9:51 AM
Yes, that is true about waiting to bore it out until he has the pistons. I would do the same...that's exactly why I wanted to source the pistons myself cause it seemed he was draggin his feet a bit. But he got em and it's underway. All good....I was just a bit anxious smile
