| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 58 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 58 | Curious where you guys source new pistons for the 216. Aluminum if possible. I see that EGGE is one...are there others?
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I got mine from Egge. Best price/availability that I could find when placing the order. As fate would have it, they were backordered and took forever to get. (or, was that the crank bearing shells?). | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I got mine from Kanter who buys them from EGGE I found out when I opened the box.
| | | | | Joined: Jul 2013 Posts: 58 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 58 | Ok. Thanks guys. I'm getting block bored out and the engine shop hasn't ordered pistons yet. I was gonna light a fire under his keester. And I see you can order them oversized in multiple sizes too on egge. So lots of options. Time to get my machine shop firing on all pistons...so to speak  | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think they are a newer style with thinner rings, at least mine were. Since I am kind of resistant to change (progress) I was quite shocked! | | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | A lot of machinests (old timers) will not bore a motor 'till he has the pistons on hand and will then bore each hole to suit a certain piston (at least the way they used to do it)--only exception I had seen was if you were ordering TRW pistons- the machinests trusted TRW's quality control enough to proceed without having them in hand. I checked a set of six TRWs for a 261 once, and found less than one thousandt inch difference from biggest to smallest piston--not bad! | | | | | Joined: Jul 2013 Posts: 58 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 58 | A lot of machinests (old timers) will not bore a motor 'till he has the pistons on hand and will then bore each hole to suit a certain piston (at least the way they used to do it)--only exception I had seen was if you were ordering TRW pistons- the machinests trusted TRW's quality control enough to proceed without having them in hand. I checked a set of six TRWs for a 261 once, and found less than one thousandt inch difference from biggest to smallest piston--not bad! Yes, that is true about waiting to bore it out until he has the pistons. I would do the same...that's exactly why I wanted to source the pistons myself cause it seemed he was draggin his feet a bit. But he got em and it's underway. All good....I was just a bit anxious  | | |
