1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#96762 08/22/2006 12:09 PM
I have a 46 Chevy that I've converted to 12 volt any way to use my factory 6 volt horn. The horn has been taken apart and cleaned and points dressed. It works on 12 but dose not sound like it should.
Thanks Tony
#96763 08/22/2006 1:19 PM
This subject was discussed a couple of weeks ago. You might try and do a search but if I remember correctly the answer was that the horn will be a bit louder but will work ok, they also said not to lay on the horn for a long time as it may burn out some of the parts.
Ed
#96764 08/22/2006 1:25 PM
Thanks for the reply I'll do a search for the old thread.
#96765 08/22/2006 3:31 PM
Ex Hall Monitor
Ex Hall Monitor
12V won't hurt it in normal usage.
#96766 08/22/2006 3:47 PM
My 6v horns have been running on 12v since before I got the truck ten years ago. As long as you don't use your horn as a weapon, it will be ok.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#96767 08/23/2006 3:48 PM
My original dual clam shells have been scaring the bejesus out of people ever since I switched over to 12v. As long as you don't lay onto the button for a real long time, it should work for ever.
Craig
#96768 08/23/2006 10:05 PM
IIRC, there is a "Tone Adjustment" screw somewhere in there. That may be what you need to look at when you say it doesn't sound right.
If it is one of those manifold-mounted deals, then it should sound like the Road Runner on Bugs Bunny.
#96769 08/24/2006 9:48 AM
Thanks for the help guys and Brendan I'll look for the adjustment screw. Right now me and old Ralph (the 46 Chevy) are headed for the Springfield Mo. swap meet.
#96770 08/24/2006 3:20 PM
I'll be looking for that adjustment screw too.. The Ox's horn is LOUD... eek
Another quality post.
Real Trucks Rattle
#96771 08/25/2006 5:48 AM
The Screw, IIRC, doesn't change the volume, just the pitch.
