| | | Forums66 Topics128,060 Posts1,055,832 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96762 08/22/2006 12:09 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I have a 46 Chevy that I've converted to 12 volt any way to use my factory 6 volt horn. The horn has been taken apart and cleaned and points dressed. It works on 12 but dose not sound like it should.
Thanks Tony | | |
#96763 08/22/2006 1:19 PM | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | This subject was discussed a couple of weeks ago. You might try and do a search but if I remember correctly the answer was that the horn will be a bit louder but will work ok, they also said not to lay on the horn for a long time as it may burn out some of the parts.
Ed | | |
#96764 08/22/2006 1:25 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Thanks for the reply I'll do a search for the old thread. | | |
#96765 08/22/2006 3:31 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | 12V won't hurt it in normal usage.
#96766 08/22/2006 3:47 PM | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | My 6v horns have been running on 12v since before I got the truck ten years ago. As long as you don't use your horn as a weapon, it will be ok. | | |
#96767 08/23/2006 3:48 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | My original dual clam shells have been scaring the bejesus out of people ever since I switched over to 12v. As long as you don't lay onto the button for a real long time, it should work for ever.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#96768 08/23/2006 10:05 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | IIRC, there is a "Tone Adjustment" screw somewhere in there. That may be what you need to look at when you say it doesn't sound right.
If it is one of those manifold-mounted deals, then it should sound like the Road Runner on Bugs Bunny. | | |
#96769 08/24/2006 9:48 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Thanks for the help guys and Brendan I'll look for the adjustment screw. Right now me and old Ralph (the 46 Chevy) are headed for the Springfield Mo. swap meet. | | |
#96770 08/24/2006 3:20 PM | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I'll be looking for that adjustment screw too.. The Ox's horn is LOUD...
#96771 08/25/2006 5:48 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | The Screw, IIRC, doesn't change the volume, just the pitch. | | |
