2 members (Peggy M, MNSmith),
240
Mod | | | Forums66 Topics128,282 Posts1,058,495 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96744 08/20/2006 5:53 PM | Joined: Jul 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 50 | I just figured out today that I only have 1 wire on my sending unit. It is the ground wire as it attaches to bottom frame of truck. I appear to be missing the wire running from the fuel guage to the sending unit. Can anyone tell me what type of wire I'll need to get and more importantly the routing of the wire from the gauge to the sending unit?
1951 Chevy 3100 w/235
#96745 08/20/2006 6:28 PM | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | The sending unit wire runs with the mane wire harness that runs down the left frame rail then it comes out just about where the gas tank is siting then routes up throw rubber grommet to the sending unit.Look to see that your wire did not brack of there at the mane harness, | | |
#96746 08/20/2006 8:34 PM | Joined: Jul 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 50 | Thanks. I'll check this evening. If I have to splice a new wire in, what gauge and type wire should I use?
#96747 08/20/2006 8:43 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Fourteen Gauge should do it.
I don't know what color to use, though.
Though, you may just want to replace the wire. If it's broken, you may have other breaks under the insulation and a new wire will solve any problems that might crop up. | | |
#96748 08/24/2006 5:34 PM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Mike the wiring diagrams call for a 18gage wire, and most of the ones that I have checked the color is Tan. Hope this helps
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
#96749 08/24/2006 6:09 PM | Joined: Jul 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 50 |
