Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Woodcmiami, Peggy M, Southerntruck), 117 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#96744 08/20/2006 5:53 PM
I just figured out today that I only have 1 wire on my sending unit. It is the ground wire as it attaches to bottom frame of truck. I appear to be missing the wire running from the fuel guage to the sending unit. Can anyone tell me what type of wire I'll need to get and more importantly the routing of the wire from the gauge to the sending unit?
1951 Chevy 3100 w/235
#96745 08/20/2006 6:28 PM
The sending unit wire runs with the mane wire harness that runs down the left frame rail then it comes out just about where the gas tank is siting then routes up throw rubber grommet to the sending unit.Look to see that your wire did not brack of there at the mane harness,
1951 Chevy 3100 Deluxe 5-window
Four generations and still not for sale!
More pictures in Photobucket
David
#96746 08/20/2006 8:34 PM
Thanks. I'll check this evening. If I have to splice a new wire in, what gauge and type wire should I use?
#96747 08/20/2006 8:43 PM
Fourteen Gauge should do it.
I don't know what color to use, though.
Though, you may just want to replace the wire. If it's broken, you may have other breaks under the insulation and a new wire will solve any problems that might crop up.
#96748 08/24/2006 5:34 PM
Mike the wiring diagrams call for a 18gage wire, and most of the ones that I have checked the color is Tan. Hope this helps
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#96749 08/24/2006 6:09 PM
Thanks 41.
Mike
