5 members (Phak1, Greg_H, GMCJammer51, WICruiser, dt235sd), 53 guests, and 0 robots.
Topics128,196
Posts1,057,395
Members48,471
Page 2 of 2 1 2
Tie rod arms came in today, ordered them through Central truck and Trailer in Hagerstown MD.
They look like just what I needed.
http://rides.webshots.com/photo/2028637100080251109saQYcZ
Next step is find tie rod ends and see if I can shorten and re-thread a tie rod I already have.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Got lucky for once!
The original tierod is a perfect fit!
Still need new ends but at least I know what Im looking for now.
The original tierod working is a good sign that I picked the right arms to get the steering geometry about right.
Grigg
---All pictures---
Grigg, I think those tanks are going to be bigger than 50 gallons. For many years I ran 22" tanks round tanks. A 57" x 22" is around 100 gallons with 90 gal draw. If they are 100 gallons, that will be 1500 lbs hanging from the side of the frame. For quite a few years it has been law that fuel tanks are marked for gross and draw. I now run 26" tanks because it gives me a little more room between the tank and the drive axle.
The tanks are 13"x18" with about a 3" radius on the long corners.
I calculated 55 gallons completely full. They have stickers but are painted over, I'll look more closely for tags but was surprised not to see them right off.
Grigg
---All pictures---
Some tanks have stamped info near filler neck rather than tag. may be filled with paint. My former boss had a tank made for a gas job DOT fined him because it wasn't certified.
I'll look again, but like I said I did look and was surprised not to see anything in the usual places. let's hope for the stamped in the tank and filled with paint option.
I misread your post. I took the 22" as the size of the tanks. You are probably right in your calculations with the size you cited. Tanks usually have a certification tag welded to them. By law, they must have the name of the manufacturer, certification, and capacity. We get scrutinized on this on DOT inspections. But I doubt if you would be scrutinized. And because it is a 53 model, you could claim that you meet 1953 standards.
Originally Posted by crenwelge
...We get scrutinized on this on DOT inspections. But I doubt if you would be scrutinized. And because it is a 53 model, you could claim that you meet 1953 standards.
Good point, they will appear "factory" although not original to the truck so probably can get away with it. The original tanks don't have anything on them that I've seen either. I do know what you mean about newer ones having tags tack welded beside the filler or stamped around the neck, the aluminum tank on my truck is an example.
Grigg
After carefull measurement I'll need to ream the taper in the tierod arms several thousandths of an inch larger so the nut will have enough room to get the cotter key in it. Taper is the right 1.5"/foot just not quite large enough.
The only ends from Spicer that fit the arms (perfect) were for a dropped tierod and I need a straight one. Then the next likely ones and commonly available would require shortening the tie rod an inch and reaming the holes some.
Using the stock GMC ends only requires the reaming, and I have the reamer.
Ends are ordered.
Grigg
---All pictures---
Edit Whole picture album here
It's been quite some time on this project and in the meantime I have been busy with other stuff and even ended up getting hitched.
Back to work, pushing to get the engine and transmission mounted in the next 2 weeks.
We left off with ordering new arms that fit the spindles and tie rods. See them here
https://picasaweb.google.com/lh/photo/norl5UeJogDlgf4o4HyBrtMTjNZETYmyPJy0liipFm0?feat=directlink
I had also ordered new original GMC 2 ton tie rod ends and had no trouble at all using them with the original tie rod tube and easily adjusted for proper toe in, 1/16". I had first thought I'd need to ream the taper in the arms a little but turns out with the proper nut it's not necessary at all.
Then I removed the old steering column/box and hung the engine as close to home as I could to evaluate the situation.
Here are a series of pictures.
https://picasaweb.google.com/lh/photo/zdsVSZBpfiJHr76SbS93bdMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/NMwkp_VHnK8o7-RLph8eodMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/9NpVGZQ-hzhPy03B0UiWgdMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/f6z9EURHS92u4UXSFRdb_9MTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/Go2d3qaCY5lIje-hq0PBIdMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/DjQPdY_eMg2Rh_YVtaOxetMTjNZETYmyPJy0liipFm0?feat=directlink
As you can see it doesn't quite fit... which I had really hoped it would because the GMC engine is longer (than the Chevy) and I could easily get another 1.5" by moving the radiator forward in the support. I had even measured and measured and pretty much convinced myself It would fit without modifying the cab.
Turns out I was wrong, the cab needs some work to fit the engine just as it did in my 2 ton Chevy, really not a surprise I guess looking at it now.
What I learned is important though. You see I often get questions form folks like "Will X Detroit Diesel engine fit in Y truck". Furthermore they'll say "I'm pretty sure it will because I found these dimensions on the internet that say the engine is only xx" long and yy" wide...." My response is always "The engine isn't a perfect cube, the only way you'll know for sure if it will fit is to set engine beside truck and measure."
Now I know even that's not enough! You've got to actually try to make it fit and see what happens.
So making it fit. For now we just moved the cab back a few feet to get some working room, in time it'll need some firewall work. Really the firewall just needs a lot more width to the existing depression, the depth is about right.
Then the front motor mount is really easy on the GMC because the old one has the same bolt spacing as the new Detroit motor mount (from 1978 GMC 6500). only the hole isn't quite large enough, an easy fix.
https://picasaweb.google.com/lh/photo/up5Nd7jY-siJkcn_D-_Mt9MTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/PxGXAzwePbEyZMpRK3S5GtMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/70a_QUjCjZkfTgzms5fc1dMTjNZETYmyPJy0liipFm0?feat=directlink
Now here it is sitting/hanging in place ready to install new crossmember from an AD GMC 470, remove old, and fab rear motor mounts.
https://picasaweb.google.com/lh/photo/DMz-lH3NXwgOGgHESQMbMtMTjNZETYmyPJy0liipFm0?feat=directlink
Grigg
---All pictures---
3B Offline
Hy Grigg, thank you so much for your photos and descriptions of your projects, very informative!
You're welcome, thanks for following along.
Here's the crossmember from the 470, it needs to fit here where it is snug because the frame is tapered (narrower at the fornt) and the uprights on the crossmember allow for that taper.
https://picasaweb.google.com/lh/photo/3sJQmJvJ9ZaxJPu906LmOdMTjNZETYmyPJy0liipFm0?feat=directlink
and from the top
https://picasaweb.google.com/lh/photo/0bPQ8Z-cweQFFpGn6y2709MTjNZETYmyPJy0liipFm0?feat=directlink
As you can see it's a lot deeper than necessary and or the other brackets on the frame don't allow it to be slid up as high as I want. My solution is to snip off about 4.5" of the uprights and drill new mounting holes.
https://picasaweb.google.com/lh/photo/E9hrCSNFAEUNep390OhCj9MTjNZETYmyPJy0liipFm0?feat=directlink
Tonight I'll get the holes drilled in the frame, bolt it in place and then remove the original transmission crossmember. If the flywheel housing weren't so large the original one would be OK, but to set the engine high enough to clear the existing crossmember would require lots of floor work to clear the transmission. Additionally one mounting ear on the flywheel housing for the starter needs to fit inside the frame or be way above the frame. So that sort of sets how high the rear of the engine can be in the frame.
Grigg
---All pictures---
More progress.
Clutch and then transmission installed, used old input shaft for lineup tool.
https://picasaweb.google.com/lh/photo/tCjraRQTncs9X5Qe6DU09dMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/rFV2rIfGqWA4cE_QPosac9MTjNZETYmyPJy0liipFm0?feat=directlink
Then after bolting in the U shaped crossmember from the 470 the old transmission crossmember had to go. Usually I use a 12" long 1" wide cold chisel and a big hammer to remove rivets, this time I tried a new tool. I think it's called a chipping hammer, like a small jack hammer and a whole lot more powerful than a common air hammer like the tool dealers sell. Less than 5 minutes had 10 rivets cut and the crossmebmer laying on the floor, no damage at all to frame, and didn't wear out my arms. It also shook loose a pile of dirt and grease from the entire frame!
https://picasaweb.google.com/lh/photo/Eb_7Lv5VvYEAo1XkyEkSUNMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/7viDTnSTpUr5rPOlSe7JrtMTjNZETYmyPJy0liipFm0?feat=directlink
And finally to set the engine in place, perhaps for the last time?
https://picasaweb.google.com/lh/photo/AGfhdRvfnwNKD6KsABB5EtMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/0zM_yqwDJgxnLpTcBVDxGdMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/qe6k0jvufC_ZF6GNheDU6NMTjNZETYmyPJy0liipFm0?feat=directlink
Next up is design and make rear engine mounts.
Grigg
---All pictures---
I was wondering how your project was going. Its looking good. The whole album puts it into perspective.
Wow Grigg another great looking project. I like the idea of adapting the larger spindles to the original axle. I thought about doing that myself not for disc brakes but for bigger drum brakes and 11 1/4" 10 bolt pattern.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Moving on to the rear mounts
https://picasaweb.google.com/lh/photo/kbNHch4jAoeOlUN1XBCxH9MTjNZETYmyPJy0liipFm0?feat=directlink
The rubber mount on the left is what I wanted to use, they look so handy and simple... but I can't think of an easy way to fab up the mounts in this case. It would be real easy if the frame was a lot wider than the engine where the mounts go but that's not the case here.
The cast housing and the rubber bushing on the right is what I'll probably use. Need to make some simple Frankenstein like pins to go on the flywheel housing and drill two 1/2" holes in the frame rails.
This will be much like the mounts on my truck, perhaps a little simpler; both use the very same rubber bushings.
https://picasaweb.google.com/lh/photo/3uuG7jwzj1ZShHSJaB6xe9MTjNZETYmyPJy0liipFm0?feat=directlink
Anyone have better mount ideas? Also has to be something I can find and make this week.
Grigg
---All pictures---
International used something similar to what you picture through 1996. In 1997 they switched to a V type block. I may have some of the old style laying around.
I wonder if that cast mount came form an IH. I know it came form the remnants of a semi truck in the junkyard, we removed them a few years ago.. but there wasn't enough left for me to recognize the make. The mounts were pins on the frame and those round castings bolted to the engine; opposite of how I'm now using them.
Pressing new bushings in the old housings. Excuse the cobbled together stuff to do so, didn't need to cut off a piece of the pipe that fit over the bushing if the whole thing fits in the press right...
https://picasaweb.google.com/lh/photo/ox-g0UwDQKQ6bN7RSBuGv9MTjNZETYmyPJy0liipFm0?feat=directlink
turned some pins and made some plates to bolt to the flywheel housing.
https://picasaweb.google.com/lh/photo/XkCcQMk86NE5leF3ZbI4CdMTjNZETYmyPJy0liipFm0?feat=directlink
First pass of weld on the back side
https://picasaweb.google.com/lh/photo/-4dBPIXRgtXb-MmNcJ3QtdMTjNZETYmyPJy0liipFm0?feat=directlink
Welded and now facing the back flat
https://picasaweb.google.com/lh/photo/UtGiZOumYa2TW-sBgt4bgdMTjNZETYmyPJy0liipFm0?feat=directlink
Parts done
https://picasaweb.google.com/lh/photo/op7ora8gu8elH6Xvs7anQNMTjNZETYmyPJy0liipFm0?feat=directlink
In place but not assembled
https://picasaweb.google.com/lh/photo/zg2o_usbv7Sk_K2HKwhh1NMTjNZETYmyPJy0liipFm0?feat=directlink
Holes drilled and bolted to the frame (same on other side)
https://picasaweb.google.com/lh/photo/AReorO7It7KDbhG9zPBxBNMTjNZETYmyPJy0liipFm0?feat=directlink
Whole thing mounted in place
https://picasaweb.google.com/lh/photo/EVMrzhx9-R3nI6lUEkRACNMTjNZETYmyPJy0liipFm0?feat=directlink
Grigg
---All pictures---
I don't think they are International. The 9000 series from mid 80's to the mid 90's mounted the journal to the clutch housing and the bushing was on the frame like yours. IH mounted it down lower and put the mount inside the frame.
Camp Commandant
Camp Commandant
Grigg, beautiful work as always. Very impressive.
~ Billy
1959 GMC 860 | Pictures
Grigg, just went thru all of your build pictures. Very nice. Looks like on the front leaf springs you've used both rear and front shackles on your builds. Did you find shackles on the rear provided less bump steer, smoother ride, less wear and tear on the suspension or is it not noticeable? I was going to go to the trouble of reversing mine on a 47 frame but maybe it's not worth it.
Thanks, Greg
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
looking back through my own pictures all I can see are shackles on the front of the front leaf springs. This truck, the 48 2 ton, 52 1 ton, and the 61 F350.
The AD COE trucks used shackles on the rear of the front springs, I haven't worked on one of those.
I believe that the steering setup has a lot to do with where the shackle is on the front springs. Ideally the pitman arm is level and if the steering gear box is forward of the axle, pitman arm moving front to back the shackle is probably behind the axle, and the reverse is true.
I haven't experience any bad bump steer on any of my trucks and wouldn't consider swapping things around just for the fun of it.
Grigg
---All pictures---
Yup. Your right of course. Must have been a different white 52 I was looking at. Guess that means it was a COE? Sorry about that. That brings up some more spring / steering box questions but I'll present them in another post.
Greg
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
Grigg and Goob the idea of running the shackle to the rear isn't for bump steer it is because as the spring is compressed it grows in length pushing the axle away from the solid mounted eye and toward the shackle. So assuming that the vehicle will spend most of its time going forward if the shackles are in the rear the axle will move a little bit away from the impact that caused the spring to compress. In the off road world guys will often move forward mounted shackles to the rear. It dose make for a softer ride and tends to break fewer parts.
user
That is a valid point about the spring shackle.
The difference between the "off-road guys" and our old GM trucks is we have short stiff springs. Which means that forward or rearward movement is minimal on our old trucks compared to what you get from a long and soft spring on an off-road buggy.
I still say it's not worth changing shackle location.
Moving on,
Put new blower shaft seals in the forward end plate and installed the blower inlet housing, crossover pipe from turbo, starter, and a lower profile cam pulley.
https://picasaweb.google.com/lh/photo/_joS5AnAcAz2iL0CtGq0StMTjNZETYmyPJy0liipFm0?feat=directlink
At this point I'm done with the "hands on" part of this build. It's headed west.
https://picasaweb.google.com/lh/photo/z1DvAAvasn3SoadUnvi-CtMTjNZETYmyPJy0liipFm0?feat=directlink
https://picasaweb.google.com/lh/photo/Nd2Aup1XeRPmxEdnr7kwxNMTjNZETYmyPJy0liipFm0?feat=directlink
So I now have lots of room in my garage to continue work on my truck at a faster pace than I have in the previous years, with some luck a much faster pace... (any progress is better than none)
Not sure if this thread will continue or if we'll see a new thread following the 53 GMC diesel conversion. I know I'm eager to see how it progresses from here.
Grigg
---All pictures---
Page 2 of 2 1 2
