0 members (), 83 guests, and 3 robots.
Topics128,081
Posts1,056,318
Members48,442
Hello Stovebolt!
I recently purchased a 48 Panel Delivery believed to have some history with the New Mexico Forestry division.
TITLE = FBA9xxxx
Door Plate = 3FPBxxxx
Can anyone here help?
Thank you in advance
chris<pixelmonkey>:D
Welcome to Stovebolt.com, Chris
Engine Serial Number: FBA9xxxx
FBA = 1948 3100 from Flint, MI engine plant
A = January
9xxxx = xxxx-1000 = serial numbers for engines from that engine plant
Vehicle Serial Number: 3FPBxxxx
3 = St Louis, MO vehicle assembly plant
FP = 1948 3100 truck
B - February
xxxx = xxxx-1000 = serial number for all vehicles from that vehicle assembly plant
http://chevy.oldcarmanualproject.com/chevyresto/4858.htm
Red dot, center of chest ...
According to the Stovebolt Vin Buster
Serial # : 3FPB1125
Mfg Date : Febuary,1948
Model : 1/2 ton
Wheelbase : 116 inches
Plant : St. Louis, MO
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Welcome to the Stovebolt pixelmonkey. I see Tim and Paul already answered your questions! Lot of information/knowledge here and great folks.
I would think the Forestry dept would have taken pretty good care of it...at least in the beginning. Sounds like a nice project. Got any pics?
Oh, going forward be sure to ask questions in the most appropriate forum as not everyone visits here. That way your sure to get answers to your questions. Good luck, and keep us posted.
thank you for the info guys!
i now have a knot in my stomach. still not sure what to think. I'm going to double check the firewall for another possible VIN number.
photo of the truck note the windows on the sides
several photos
hope to find an answer to the title problem soon. The previous owner is checking with the DMV for a Letter of Correction.
I'll keep everyone posted!
There's no question it's a '48. That's the only year that the gas tank was mounted on the frame behind the cab. Since it came out of New Mexico, I think the St. Louis plant is more likely the point of origin. Also, the serial numbers were on the door plate that year, so that would be the original location for it. That's why I only decoded that one. The '48 panel truck was a 1/2 ton model on a 116" wheelbase, so that is correct as well.
Title serial numbers are often unreliable. Depending upon the state they got the serial number from the motor, the door jamb or other places.
Paul Schmehl CI 6
geek@stovebolt.com
yes, your title "vin" simply used the engine number, most common back then, if it still has that engine, the number will be stamped on a pad just behind the distributor, if it's not the same engine [or no engine], then the "letter of correction" or a DMV inspection is in order
BIG thanks to tclederman and bladeagle!
The next step in the process is to have the man I purchased the truck from file for a "Letter of Correction", then I can get the title in my name with the VIN corrected. This process will take around 1 month and might require a few photos for him to take to the DMV.
The other option is for me to file for a Title 42 *lost title for vehicle* and will take around 3 months.
Either way, I'm OK with the end result.
