4 members (Simon1954, klhansen, Joe H, baldeagle), 82 guests, and 11 robots.
Topics128,019
Posts1,055,343
Members48,419
#965473 08/20/2013 9:05 PM
I have a 1965 V6 GMC long bed step side 8 bolt wheel how can I tell what size this motor is
Thanks bob
Bob May
Not sure where the engine number is on your GMC but if you can find it I know some guys here can decode it. There is also a vin buster here on the bolt so check out your vin number and see what it says to.
Welcome to Stovebolt.
You'll find info on the V6 and lots more here.
That is not meant to say you aren't welcome on this site.
I'm not aware of any 'VIN buster' for GMCs but there is serial number info on the 60-66 site also.
Cletis #965707 08/21/2013 1:57 PM
I'm not absolutely positive, but I thought all the 60-66 GMC V6's were 305cid, at least in the 1/2T - 3/4T trucks.
I think he asked how to tell what size his engine is, not what size engine it came from the factory with. They may or may not be the same.
This appears to what will decode the engine and where to find the numbers. Looks like GMC continued with putting the engine displacement at the start of the serial number, like the earlier GMC engines.
Bill Burmeister
I think they used to just stamp the size of the engine on the top manifold pad....like 305 or ?
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
