1 members (69Cuda),
73
Mod | | | Forums66 Topics128,096 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | It seems that Zero Rust is a favorite for priming but I don't know what to use as a top coat. I called Zero Rust and they said that even though they have colors, their paints were primers, not finish coats. I asked for their recommendation for top coats over their primer and they would not offer a recommendation.
Two questions:
1. If I use Zero Rust as a primer, what brand would others recommend or perhaps have used as top coats?
2. Should I just go to a complete Rustoleum system and use their automotive primer or restorer and then top coat with Rustoleum paints?
I'm only addressing the areas I can access after pulling the bed so I'm not looking for the ultimate finish on the frame, just an effective way to protect it properly. All the parts under the cab will still be rusty. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Zero Rust has a clear coat that seals the 'primer' - the only problem with not top coating ZR is it doesn't have UV protectors, which shouldn't be a big problem on a frame - if you already have the ZR, try some other satin or gloss on a test piece, Rustoleum could work fine over it or alone with no primer and is cheaper, I've done both, happy with either Bill | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I ZR my entire frame and then used ZR clear-coat afterwards for the very reason Bill mentioned...UV protection. It really looks good too! | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | Does much UV light get to the frame unless you roll the truck?
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
