4 members (BC59, TexasA&M48Truck, Jays58, KEVINSKI), 106 guests, and 2 robots.
Topics128,096
Posts1,056,473
Members48,444
It seems that Zero Rust is a favorite for priming but I don't know what to use as a top coat. I called Zero Rust and they said that even though they have colors, their paints were primers, not finish coats. I asked for their recommendation for top coats over their primer and they would not offer a recommendation.
Two questions:
1. If I use Zero Rust as a primer, what brand would others recommend or perhaps have used as top coats?
2. Should I just go to a complete Rustoleum system and use their automotive primer or restorer and then top coat with Rustoleum paints?
I'm only addressing the areas I can access after pulling the bed so I'm not looking for the ultimate finish on the frame, just an effective way to protect it properly. All the parts under the cab will still be rusty.
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
Zero Rust has a clear coat that seals the 'primer' - the only problem with not top coating ZR is it doesn't have UV protectors, which shouldn't be a big problem on a frame - if you already have the ZR, try some other satin or gloss on a test piece, Rustoleum could work fine over it or alone with no primer and is cheaper, I've done both, happy with either
I ZR my entire frame and then used ZR clear-coat afterwards for the very reason Bill mentioned...UV protection. It really looks good too!
Does much UV light get to the frame unless you roll the truck?
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
