| | | Forums66 Topics128,203 Posts1,057,414 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 60 | I noticed yesterday that the transmission end of my speedometer cable on my '39 is just hanging around. It appears to mount to a hole in the left side of the transmission but all I have is a hole, basically, that doesn't seem quite big enough and is also not threaded. What am I missing, exactly? Hope this isn't bad news...
Thanks.
Dan
1939 1/2 Ton 1968 K20
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I don't know if this helps. I had a similar problem on my 46. There is supposed to be a double male-threaded coupler that screws into the transmission and onto which the spedo coupler screws. Bob
BobS46
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Is the hole an open hole into the transmission? There should be a speedometer gear that screws into the case and it has threads that the speedometer cable housing threaded nut screws onto then. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It would help if you could link to some pictures.
See the USA in your vintage Chevrolet! My Blog | | |
