1 members (MickeyP),
84
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I'm considering upgrading my truck to a 350 with an automatic transmission.
Is there a general consensus on which route I should take. Money is a factor. I was considering doing the S-10 Frame Swap but I was thinking, I don't mind the rough ride of the leaf springs personally. So is there any other drawbacks to taking the 235 out and dropping a 350 in? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Your steering box is going to be in the way, you will also have issues with the exhaust manifold/header on the drivers side. It can be done but its not going to be cheap. Do some more research before you make up your mind. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I have looked online but part of my research is not reinventing the wheel. If y'all have a place that spells these options out that would be great. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Try the HiPo forum of this site. | | | | | Joined: Oct 2011 Posts: 2 Moderated | | Moderated Joined: Oct 2011 Posts: 2 | Some people just cannot leave their trucks half way original. Always an automatic. I guess some cannot drive a manual transmission. oh well. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | I'm driving it w 3 on a tree now...it's just easier w an auto | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | FPMnky, its your truck so your free to do what you like and what your pocket can afford and use what parts you have. I went the V8 route in my panel because the rest of it was pure tee junk. I used what I had, straight axle with power steering, 305 engine and 350 tranny. Changed the torque tube out for a different pumpkin. it was that or the crusher so I figure I saved at least one Stovebolt! Check out my photobucket and feel free to ask question if you like by PM.... and in the driveline. There is some cost involved but it don't have to break the bank. Guys here will help you a long and offer advice along the way. Good luck. | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | There are lots of trucks forsale that already have the options your looking for. Its sometimes cheaper to just do that, less trouble and saves a relic too boot.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Here's what I did & kept the straight axle.
use a dropped tube (TransDapt) SBC engine mount for your truck buy the power steering conversion kit buy the disc brake conversion w/ firewall mounted master kit (makes exhaust routing easier) buy the 1 inch tie rod/ tie rod end kit and the 1 1/8 in. stabilizer bar kit buy the trans crossmember for whatever trans you select
You'll have a nicely re-powered truck and an upgraded steering/brake/suspension to handle it without frame conversions, etc...
I did all of the above with 455 Buick instead of an SBC. Steers with one finger and stops on a dime with leaf springs all around.
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | You can reverse the exhaust manifolds from a SBC 265 (if you can find them) and that will give you steering box clearance. SBC are like belly buttons. Everyone has one!! | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | ya know you can get alot of horsepower out of a 235 and shock the hell out of a lot of people.....I have a 46 chevy 1/2 ton and I removed the original 216 and I built a 235 with close to 400 horsepower backed to a t-5 transmission and a 9 in ford rear, and didnt have to do any modifications except for the rear and the brakes upgrade, I even still have the foot starter.......I was at a street race lately and everyone thought it was a joke, and I went up against a 73 camaro,and smoked him, I got back to the line and people were asking alot of questions about my motor......just sayin....... dont need to go the v-8 route to have the power..... | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | No, you don't have to reverse the 265 exhaust manifolds, you just use the driver side one on driver side, it dumps out between first 2 cylinders and avoids the steering box. At least that's how my 265 manifold is made. The driver side is the issue. If you've got room, ramshorns are nice too and don't require any maintenance, but they dump in middle (closer to steering box). You could likely use about anything on passenger side. | | | | | Joined: Jul 2011 Posts: 257 Shop Shark | | Shop Shark Joined: Jul 2011 Posts: 257 | ya know you can get alot of horsepower out of a 235 and shock the hell out of a lot of people.....I have a 46 chevy 1/2 ton and I removed the original 216 and I built a 235 with close to 400 horsepower backed to a t-5 transmission and a 9 in ford rear, and didnt have to do any modifications except for the rear and the brakes upgrade, I even still have the foot starter.......I was at a street race lately and everyone thought it was a joke, and I went up against a 73 camaro,and smoked him, I got back to the line and people were asking alot of questions about my motor......just sayin....... dont need to go the v-8 route to have the power..... Your right, but he also said he was on a budget, can't imagine how much that cost you.... | | |
