| | | Forums66 Topics128,269 Posts1,058,398 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 29 New Guy | | New Guy Joined: Mar 2013 Posts: 29 | I'm working on reassembly and have run into a stop work issue. It's the formed pieces of metal that clip onto the inside of the fenders. I have the new seals but the formed metal that the old seals/gaskets are stapled to are to rusted to reuse. There are two pieces for each fender .. 1ea "L" shaped at the top of the fender and 1ea that is about 20 inches long that runs top to bottom of the fender. Anyone know of a source for new?? | | | | | Joined: Aug 2005 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 37 | I don't believe anyone sells new but checkout RJ in parts for sale.He lives in Colorado. He should have what you need.If not I have a fair set. Gerry | | | | | Joined: Mar 2013 Posts: 29 New Guy | | New Guy Joined: Mar 2013 Posts: 29 | Thanks Gerry, I know RJ I'll give him a call. Thanks for the offer to sell your set. | | | | | Joined: May 2007 Posts: 1,721 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,721 | Larkspur, I ran into same problem recently. The "L" shaped dust seals had to be fabricated which I found someone to work locally. I can't help you there other than to confirm, not likely to find unless RJ can help. The long pieces I retrieved from donors in the junk yard. Since they are not reproduced, I grabbed extras. Send me a note if you would like pictures of the pieces I have stored in my garage, looking to go to first who needs (you?). [email protected] | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Also check tony at 456 chevy thats where I got mine. | | | | | Joined: Mar 2013 Posts: 29 New Guy | | New Guy Joined: Mar 2013 Posts: 29 | Thanks to all for the responses!
I drove down to see RJ (Rich) today and picked up the pieces I needed. Man o Man has he got he rare/hard to find parts! | | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | Steve, it was nice to see you again, Thanks for your purchase. glad to help out with parts.
