2 members (klhansen, Hotrod Lincoln), 89 guests, and 0 robots.
Topics128,050
Posts1,055,641
#963075 08/12/2013 6:22 PM
what is a reasonable price for a built drive shaft ? Nothing fancy just one for the 51 truck with 8.8 rear end and the ls=1. I have already converted the 8.8 rear flange to standard u-joint. I did not by the flange adapter but instead removed the flange and installed the correct u-joint.
Shouldn't be too much. My son-in-law had one built for $200. He had to provide the dimensions and buy the universals after it was finished.
Drew
As I suggested to someone here recently, go to your driveline shop and see if he has "trade in's". Most true driveline shops will have a few stashed back and can usually cut to length and balance. Since you changed to u-joints they are not that expensive. Its worth checking out.
Achipmunk #963203 08/13/2013 5:03 AM
Yes they can do the work, I will have to get measurements so they can make and balance. What would be a good price for a new one ?
V
V Offline
We're lucky in our area, we have a very good shop and reasonable. Last one I had cut, welded, new joints and balanced--$85.
