| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Please, somebody tell me that I can rig the two speed differential to high. I'm driving my latest buy from Salina, KS to El Paso, Texas and the first 90 miles has been in low gear. I noticed the hoses were dry rotted and one had come loose so I got some at Autozone and replaced them and got it to shift once. But like a dummy I shifted back to low to see if it was really working and now it's stuck in low again. I'm guessing the diaphragm is shot and I'm hoping somebody knows a trick to shift it to high without using the splitter so I can drive the next 686 miles on high.
Please call me at my hotel if you can assist me in my time of need. (620) 792-8235 room 208. Or reply if the solution is not too involved and can be explained easily.
Raul
What's the difference between an adventure and a nightmare?
The way you see it and the way it affects your pocket book.
I'm staying positive though.
Please, calling all cars!!!
Glory Bound...
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Use a burst of compressed air on the opposite side of the diaphragm. Go to a service station and ask to use their inside air hose with a nozzle. Remove Both hoses from the lines, not the module. Ear close to the diff. A shot of air in the hose to the Outside of the module (closest to the wheel). Should hear the clonk. If no clonk, try other hose. Try driving it. May have to roll truck a few inches to line things up and try again. Leave hoses off until you get home. | | | | | Joined: Aug 2001 Posts: 3,591 Moderator | | Moderator Joined: Aug 2001 Posts: 3,591 | rautru Jim's advice sounds like something I should also remember. Let us know how the adventure turns out.
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Aug 2001 Posts: 3,591 Moderator | | Moderator Joined: Aug 2001 Posts: 3,591 | Jim, shouldn't the vacuem lines also be capped off to mantain engine vacuem or does the shift valve, control that? If you do need to cap the lines, just get a piece of small pipe and hook them back to each other. Hope this helps and not hinder.
2-Ton
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Thanks for the feedback. I shall try that this morning and keep you guys posted
Glory Bound...
| | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | I took it off the differential, switched it manually, then reversed my vacuum lines at the control valve. Seems to be working. Getting ready to take off again.
Glory Bound...
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Any pictures of the trip ? | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | I did pack my camera, or so I thought. As it turned out it was the rechargeable batteries and charger in the case. My wife had put them in there and didn't tell me. She did manage to take a couple with her phone though. I've read the instructions on how to add links to pics, but still haven't got it. Will add some once I do.
By the way, she didn't make it. After getting stuck in the mud in Great Bend, Kansas and being pulled out by a tow truck we made a hell of a run , 434 miles, from Great Bend, Kansas to Santa Rosa, New Mexico. As I pulled into the gas station the brakes went out. The compressor went south on me. Then the starter shorted out. She's staying there for a week and I'll be towing her home the last 262 miles. After that debacle she's got a name, Lucille, cuz she just won't do her daddy's will.
Glory Bound...
| | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | Sounds like a good candidate for a Saga Submission!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | I shall try my hand at writing and see what I come up with for a saga.
Glory Bound...
