3 members (Otto Skorzeny, Shaffer's1950, Uncles51), 96 guests, and 3 robots.
Topics128,139
Posts1,056,462
Members48,441
#962246 08/09/2013 1:47 PM
I got a new fuel pump for my 55.1 Model 3100 and the position of the inlet and outlet for the fuel lines on the new pump don't seem to be right. The existing pump routes the lines parallel to the engine block, but the new one wants to angle the inlet line away from the block and angle the outlet line towards the block. It seems unlikley that it would accept my existing fuel lines. I have confirmed that the new pump is listed for a 1955 Series 1, and the various catalog listings don't mention a variation in fuel line positions.
Are my existing pump and fuel lines incorrect replacements? Do I need to replace the pump to carb line and maybe the tank to pump line too?
Or should I just find a pump with the same fuel line position as my existing lines? How do I make sure I get the right one? Go to NAPA and make them show me diffent pumps?
Thanks!
Trooper Jeff
Trooper Jeff
If I can't drive my truck, fetch my horse
"Courage is saddling up even though you are scared to death" - John Wayne
The pump lines for trucks run parallel to the block. The pump lines for cars come out on a slight angle to clear the motor mount that is on the side of the block near the pump. You can bend the lines to line up with the car pump. I had to do that with my 235 w/powerglide car engine in my 3100.
Trooper Jeff -
I believe that you have the correct pump for your 55.1 truck. The pump was changed in the early 50's as Carl noted, but it was used on trucks too. Don't know when the switch from glass-top to metal-top was made. I don't know of anyone that supplies a line with the correct bend for pumps with the 20-deg angled ports. I bent the pump-to-carb line for my '54. Was pretty easy. I left the old mangled tank-to-pump line on the truck. May bend a new one someday.
FYI - GM supplied a 20-deg fitting to adapt the new pump for older trucks.
- Lonnie
- Lonnie
My '54 3104
For anyone trying to address this issue, I spoke to the folks at Jim Carter and found out that they have the original truck style pump, metal top with the fuel line ports with no offset. My new pump just arrived and it looks good. Should be able to install it with no fuel line modifications. Can't wait to find a few minutes to bolt it on.
Trooper Jeff
Trooper Jeff
Also don't forget, you can rotate the bottom housing on the
fuel pumps to reposition the inlet and out let.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
