2 members (51sub, Possum),
113
Mod | | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 99 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 99 | 53 Chev 2 ton COE. Anybody know the easiest or proper way to adjust the door hinges? Typical problem, the door is scraping against the cowl when it opens and closes. The top hinge does not look like the factory service manual says it should. Thanks. | | | | | Joined: Apr 2007 Posts: 1,044 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,044 | George, As best I can tell from your photobucket pictures, you have the correct top hinge. Perhaps you could put a better and closer picture on your photobucket for us to see. I think the service manual shows a standard cab, which has a different top hinge than your COE. Both of the hinge "straps" inside the door have slotted holes. These allow you to adjust the door in the opening. The top hinge is behind the cardboard panel at the top of the door. The bottom hinge is accessed after removing three hole plugs(which is very different than a standard door). These plugs are often missing and you may just have the uncovered access holes. By gently loosening the bolts you can tweak the alignment of the door. Hope this helps. By the way, I didn't see you this year at the Watson Lake show!
Kent
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | George, Can't remember if I asked you if you plan to keep your truck a dump truck, or convert it back to a Road Tractor? That's a neat lil' truck. I had a '53 5100 Tractor just like it. | | |
