2 members (pdlightning, Tronman), 104 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
I've searched, but I can't find any help for this....
I have a 1961, 261 and a 168 tooth (12v), 11" flywheel. I cannot for the life of me find a 12 volt starter anywhere. Does anyone have any idea where I can find one? Thanks.
Joe
PS This is going into a'41 Chevy sedan.
A 6 volt starter will hold up fine...have this set up on my 54 6500 for years now,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
A 6 volt starter will not work with a 168 tooth flywheel.
Joe,
What year truck are you putting this in?
If it is in a 1961 truck, most likely you are looking for a solenoid starter. NAPA, Rockauto.com, and many others should have a 12v starter with solenoid for 235s. It should work fine.
You most likely have an 11" clutch - the size of the clutch has no impact on the suitability of a starter.
Sorry for not mentioning this at the top. It's going into a 1941 Chevy sedan.
NAPA, Rockauto and many others do NOT have this starter. At least not that I can find. If you find one, I'd be elated and grateful.
Thanks.
Joe
Also, a shop that rebuilds alternator, geneorators and starters will likely have one.
Do you want a 12v solenoid starter or a 12v foot-actuated starter?
Do you have a starter you can send in to save on the core charge?
the year it's going in matters not ... got a local auto electric shop around? check with them, they should be able to rebuild one for you, all the parts are available - or try ebay - one and another and yet another
Thank you to all who replied.
I went and checked the 4 starters that I have (all "stomp" starters). One of them DOES have the smaller shaft and does "twist" as it engages. So now all I have to do is figure out when it's not meshing well with the flywheel.
It doesn't want to "engage", but if I "force" it, it will.
Then, once it's engaged, it wont fully release. Again, force will help to release.
Joe
