Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Hotrod Lincoln, Otto Skorzeny, Phak1, Gdads51), 56 guests, and 0 robots.
Topics128,007
Posts1,055,278
Members48,418
#956632 07/15/2013 9:43 PM
What would it take to fit a 1947 (late) body on a 1965 frame? Both are 3/4 tons.
check the width of the frames and spacing of the cab mounts on each and position with respect to the radiator, as well as thinking about how the rad would mount, considering the 47 front clip mounts to the rad
the 47.2 to 55.1 has a narrower frame/cab/track width
Sir Searchalot
Sir Searchalot
It would take a lot of work, there are many, many things to consider. Wheelbase, cab mtg, gas filler, tranny hole, ebrake, steering, pedals and linkages, bumpers, body to frame "nesting" and as Red said and as Scott said and lots more. Most of the time they look like what they are.
It's a bunch of work and when you are done the tires stick out just a little bit past the front fenders.
The S10 is the more popular frame swap.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Dachshund,
The placement of the motor between the radiator and the firewall can be an issue, if you're trying to use the stock engine mounting holes. We had to move our V8 mounting back about 5" to clear the radiator. be flexible and change what you will need to.
2 shiny bolts show our stock mounting location
moved it
I'm planning on using the stock motor/trans.
headscratch Do you mean the 47 engine/trans?
Are you just trying to upgrade the steering and suspension or is your frame shot?
Might be easier to rework your frame and add better suspension and steering.
Anything is possible with enough money.
