1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Got old spindles off (Thanks KoolKar)getting ready to install new old spindles on 59 Apache. Going to put bolt on disc brake system (drums back)seeing and reading about all the systems sold I don't know if I want to put master cylinder/filler under cab as orginal m/c under cab filler on firewall or the whole unit on fire wall. Anybody done this what do you ol wise ones think. Done tearing apart ready to start putting back together. Frame gets painted in 2 wks. I HOPE. Engine compartment getting 350 w/headers th400 trans will this change my options?? Question, Questions, popcorn.
The Truth is Out There | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | If you put a new master in the stock location it saves you the effort of reinforcing the firewall (I've heard tales of cracked firewalls from the stress of the pedals). I don't know how a new master will fit under the '59 floor, but on my AD the resevoir does not match the fill hole in the floor. A remote filler on a "stock location" master would be my choice. | | |
