5 members (Jon G, Otto Skorzeny, Hanks custodian, dt235sd, 3800GUY), 166 guests, and 1 robot.
Topics128,105
Posts1,056,205
Members48,436
#95935 06/15/2006 4:46 AM
Do the 60-66 Chevy factory tachs require a transmitter to work? The one that LMC sells apparently doesn't need one, but I thought maybe it has been modified to work without a transmitter like some companies do to the older Sun tachs.
Thanks!
#95936 06/16/2006 5:12 AM
I don't know.
What wiring options do you have? (i.e. are the terminals labeled?)
I've got an aftermarket tach in mine and it only has the three wires - Hot, Ground, and Distributor.
If the unit is deeper than an inch, you probably don't need a brain box. If it's a shallow thing, then you probably do.
What is wrong with the one that you have?
#95937 06/16/2006 5:47 PM
My gauge equipped instrument panel never had one installed. I'd like to install one with either the original type or modify the cluster to fit in an old sun tach. I have found so far that the FZ-88N (similar in design to the factory tach) doesn't need the transmitter, but I would have to figure out how to modify the cluster to allow the tach to look factory.
Larry
#95938 06/16/2006 9:11 PM
12v 8cyl?
#95939 06/16/2006 11:09 PM
Forgot! Yes, 8cyl and 12 volt. I'm used to only V8 vehicles having tachs, like Camaros.
Larry
