1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95935 06/15/2006 4:46 AM | Joined: Apr 2006 Posts: 14 New Guy | | New Guy Joined: Apr 2006 Posts: 14 | Do the 60-66 Chevy factory tachs require a transmitter to work? The one that LMC sells apparently doesn't need one, but I thought maybe it has been modified to work without a transmitter like some companies do to the older Sun tachs.
Thanks! | | |
#95936 06/16/2006 5:12 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I don't know.
What wiring options do you have? (i.e. are the terminals labeled?)
I've got an aftermarket tach in mine and it only has the three wires - Hot, Ground, and Distributor.
If the unit is deeper than an inch, you probably don't need a brain box. If it's a shallow thing, then you probably do.
What is wrong with the one that you have? | | |
#95937 06/16/2006 5:47 PM | Joined: Apr 2006 Posts: 14 New Guy | | New Guy Joined: Apr 2006 Posts: 14 | My gauge equipped instrument panel never had one installed. I'd like to install one with either the original type or modify the cluster to fit in an old sun tach. I have found so far that the FZ-88N (similar in design to the factory tach) doesn't need the transmitter, but I would have to figure out how to modify the cluster to allow the tach to look factory.
Larry | | |
#95938 06/16/2006 9:11 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | | | |
#95939 06/16/2006 11:09 PM | Joined: Apr 2006 Posts: 14 New Guy | | New Guy Joined: Apr 2006 Posts: 14 | Forgot! Yes, 8cyl and 12 volt. I'm used to only V8 vehicles having tachs, like Camaros.
Larry | | |
