2 members (Wayne67vert, 66flea),
297
Mod | | | Forums66 Topics128,156 Posts1,057,018 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I have managed to remove the nuts that holds the outer rear wheel. The inner rim is now hanging ont the bolts that has a square fitting in the outer end. Do I have to remove these bolts for the inner rim to come off ??? Or is it just a matter of using a big sledge hammer and give it a punch or two ? Or are the threaded bolts sitting on other bolts coming out from the brake drum ? I mean are these bolts threaded on both inside and outside ? It took me half day to just get the outer rim nuts to give up. But finally they did  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, yes the objects with the square end are indeed the inner wheel nuts, once you remove them the wheel will come off. Don't forget the left side of the vehicle should have left hand threaded wheel mounting hardware, there should be a small "L" in the center of the inner nuts to remind us, hope that helps. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | The 4-end bolts have an R on the right side and a L on the left side. Does this mean I shall turn the 4-end bolts the same direction as I did with the outer wheel nut ? In that case, why did not the wheel nut pull the bolt out too then ? Or is the inner bolt supposed to be turned the other way ?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | if it has an R on it everything about it is normal threaded, anti-clockwise is loosen.
If it has an L on it everything about it is left handed thread, clockwise is loosen. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I POURED penetrating oil all over the bolts. Just need to find a 13/16" square socket somewhere around here ... will be really easy  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I have never seen a ball and seat wheel in Europe. I looked through a catalog of KS which is kind of the equivalent of our Ken Tool. http://www.kstools.com/de/flippdf/K11/Lkw/Lkw_D/files/lkw_gesamt_ob.pdfI can't find a square socket for the inner nut. If you can't find one in Europe, I will be in Germany middle of next month and it is reasonable to mail something within the EU. A made in USA inner nut 1" drive socket can be bought for about $36 which is about €27. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hello,AGAIN,Ulf!! I did the exact same thing today,on the '59 Viking!! (Small world)! In order for us to loosen any of the bolts,we had to use an industrial impact wrench. Make sure to hold on tight,and don't lose concentration,for a second! Those things have SUPER TORQUE,and just about took my friend's nose off,a couple of times! Luckily,the impact also loosened MOST of the inner BOLTS,as well. On the stubborn ones, we used the 13/16" bar,that came with the bus,along with a 5' "breaker" bar. One of us would stand/jump,on the bar,as the other hit the bolt,kind of like a manual impact wrench. We have had no luck removing the hubs. we can pry them from the back-side,but seem to "spring" back into place,as soon as pressure is released. Yes,we turned in the "Stars". No sign of hub freeing itself from axle,though. We even used a torch,to no avail. I saw a thread on this subject 2-3 weeks ago,and try to use the method(s) from that post. I'll send you a P.M. B.T.W...Glad you still have your Viking!
| | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | On early trucks, most times, the studs are pushed through the drum in to the hub. When you want to separate them you need to push the studs out. Can be done with a hammer and a drift but better in done on a press. Budd nut #1 Budd nut #2 | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thanks all. I have a friend who owns a tire shop. That's where I got the outer nuts loosened. Drove home with all 6 bolts just barely tightened. I still had to use a socket and wrench tool and put a LONG tube on top and JUMP them lose  They have the tools for these inner bolts too. I will go there today and borrow one. They use them because Toyota have the SAME setup in newer smaller trucks with dual rear wheels  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | They didn't have the 13/16 socket. BUT I did find it at a toosl shop, they order from factory, takes 4 days to get it. Made in Flen Sweden, just 40km from where I live !!! Powersocket cost me 50 usd  So in mid next week I can finally start working on the brakes ( if I can get the drum off ) But that is another story  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Guess I was lucky on mine. A neighbor had a HUGE 4-way lug wrench he let me use. It has 3 sizes for lugbolts and one for the square-end, inner lugbolts. I put one end on the lug and the other end on a concrete block, then with a 10 ft. pipe slipped over the 4-way and jumped up and down and got all mine off. Matter of fact, he just gave it to me. They don't make a 4-way that strong anymore!
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I just got my new socket: http://i185.photobucket.com/albums/x264/uffeg/20130730_145942_zps6879f09a.jpgAnd I was just about to start removing the studs when heaven opened up and poured BUCKETS over me. But I tested ONE and it gave up on my new socket and a LOOOONG tube over the wrench !! Next step is, WAIT FOR SUN !! Then remove all of them. After that start fighting with next obstacle: The brake drum  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Yep, sometimes you have to use brute force, like the 8 ft. long pipe. A 3/4 impact won't do it sometimes. Mine would not remove the pinion nut on the rear end. Had to use a long pipe. Lucky I did not have a bed on it.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I have a wide bed on mine. Have to ose a longer shaft, and put a jackstand on the ground to support the longer shaft  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | A 3/4 impact won't do it sometimes. That's where a 1" gun with a big air hose comes in handy. | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | When I took my wheels off the 1st time I got nowhere with the wheel tool I had and nothing in the shop I was working at budged them. I had to take the hub apart, pull the wheels drum and hub as one unit, then took them to a tire shop that handles trucks. They had a splined 1" impact gun that looked like a jack hammer, spun them off no problem. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Yet another victory today : The drum is also gone !! Used a screwdriver as seen in the picture here, square handle where a wrench fits. Leaned all my own weight on it and bam they went lose. http://i185.photobucket.com/albums/x264/uffeg/20130731_105209_zpsa7c39b26.jpgThe drum came off after a couple of pounds with a sledge. The brakeshoes are thick. Will try to remove the rust and remove the wheelcylinders and see if they move at all. If not I will need new cylinders. All springs are there, so I guess it must be stuck cylinders. Also, SOMEONE ELSE lives inside my drum !! http://i185.photobucket.com/albums/x264/uffeg/20130731_105218_zps75e57700.jpg My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Tried to apply a little brake pressure with the pedal, only the rear wheelcyl opens a little bit, the front cyl does nothing. So I guess I will need to remove both and try to repair them or just simply buy new ones. Maybe the reason for only the rear cyl to open is due to the drum is off ? But I thought the fron one is the most important one. At least this explains the bad brake on this side. I hade to beat the shoes to free everything up. But the front cyl will not compress or decompress  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Can somone explain what Geoffrey at Alretta Truck Parts means with this comment: "I'm sure I'll have wheel cylinders. I'll want you to check the show table width: 4", 4.5", or 5"? I hope these shall not be a problem." Is it the cylinders or shoes I shall check ? and how  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Brake Shoe width?? Maybe different cylinders go with each brake show size/width. Your project is going well. So far so good.
SimS
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy lastchancetowing, Geoff wants to know the brake shoe width, I believe 4" width is Bendix (crossover brake line is inside the drum) the wider shoes are Wagner brake systems I believe (crossover brake line on backing plate). Your pictures are of Bendix brakes, if you damage the crossover line DO NOT THROW AWAY THE TUBE NUTS WITH THE DAMAGED LINE, these nuts have a different pitch than the standard tube nuts and are hard to find. You can transfer the Bendix nuts to the new crossover line you fabricate and you'll only have to make one flare on one end, hope that helps. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thanks... I mailed him all info and attached a couple of pics.
And the crossover line seems to be in very good condition. I will be very very careful when I remove the wheelcylinders so I can reduce the risk of harming the nuts or the tube.
The good thing is , I now know why the braks were bad on one side since only one cylinder works, the front of the two is really stuck.
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Geoffrey is of course right when he says you shall always change shoes and cylinders on both sides at the same time. But, breaks are very good on left side. Even the right side works on one cylinder, even the shoes are good  and the drum looks perfect inside. Maybe just remove the cylinder and see if I can get it to work better and then change it all during winter. "The wheel cylinders should be replaced in pairs. Never do only one side: that's a fast way to put back pressure in the other side and have that leak. Wet shoes are ruined. Remember, no brake drums are available!" So I ask for opinons here please. Do a complete change ? Or try a quick and dirty ? My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | If everything looks good, material, springs, etc., just rebuild the left and right wheel cylinders and call it a day. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I have new cylinders and adjusting kit for right side in the air somewhere between Alretta Truckparts and here  300 USD including international fast shipping is a bargain !! But I will remove the cylinders and check the numbers, since both Volvo and Scania used Bendix brakes in the 50's and 60's. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Just got a SMS from post office. My parts are here !! Now I will see how stuck the cylinders are to my truck  The springs will surely be a struggle to get out without shooting them to the next county. they are NOT that small  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | I get so happy when I receieve a mail like this:  Yes but I had pressure everywhere wnd no air, just changed the right rear cylinders, so I don't think air travel all over the pipes. But we'll see, I will bleed it tonight, caught a nasty cold so haven't been able to proceed. Another thing, how happy do you get when you receive these kinds of mails ? VERY !!  Ulf, Just a verification that parts arrived and its all good? Geoff -------------------------- Alretta Truck Parts, Inc. Bldg.#5B, 2nd floor One Watson Place Framingham, Ma. 01701 Tel# 508-788-9409 Fax# 508-788-9499 Mail to: Alretta Truck Parts, Inc. PO Box 596 Sherborn, Ma. 01770-0596 http://www.alretta.com"Where Parts are a Science and Service is an Art!" My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I get so happy when I receieve a mail like this:  Yes but I had pressure everywhere wnd no air, just changed the right rear cylinders, so I don't think air travel all over the pipes. But we'll see, I will bleed it tonight, caught a nasty cold so haven't been able to proceed. Another thing, how happy do you get when you receive these kinds of mails ? VERY !!  Ulf, Just a verification that parts arrived and its all good? Geoff -------------------------- Alretta Truck Parts, Inc. Bldg.#5B, 2nd floor One Watson Place Framingham, Ma. 01701 Tel# 508-788-9409 Fax# 508-788-9499 Mail to: Alretta Truck Parts, Inc. PO Box 596 Sherborn, Ma. 01770-0596 http://www.alretta.com"Where Parts are a Science and Service is an Art!" � | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Strange I tried to post this twice tonight but only empty boxes appeared. Maybe web service was doing backups or something ? Anyhow the point I wanted to make is that there is almost NOWHERE existing a company where they send amial asking if your parts got home alright  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Ulf, when you paste something in from another application [the e-mail], you need to change the drop box below to "using HTML and UBBCode" in order for the software to recognize the coding  Bill | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Aha... sorry, would have known. Should have copied to notepad to get rid of all formatting first. Tried to post in several posts, same problem  Thanks for pointing it out, I am a IT loser  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
