6 members (Leo, Jon G, Otto Skorzeny, Gray_Ghost, klhansen, 1 invisible), 116 guests, and 4 robots.
Topics128,181
Posts1,057,187
Members48,465
Page 1 of 2 1 2
It started a little over a year ago. My father-in-law asked if I wanted to help build/restore a truck. I have always been the do-it-yourslf type for the most part. So site unseen I said yes.
Edit August 2023: Read the rest of the truck story in the Gallery entry by Thad from July 2013. thumbs_up
This is what we started with (see images below): first, teardown, bare Frame (almost).
We decided to turn it into a street rod (I did not know what that really mean at the time).
Decisions, decisions... Being an engineer by trade, that meant research, research, and more research.
We decided on a SBC 327 so we found one from a '64. It is now 0.040 over, 9.5:1 compression, 270H comp cam, balanced, Full MSD ignition, EZ-EFI, ect:
It also has a TH-350 that is built up just a little.
Rear from a 93 Ford Explorer, perfect fit with explorer springs and fabed brackets (oddly a 3.27:1 ratio :D: ) pix
TCI IFS pix
Exhaust, Drive shaft, Shocks:
Currently have a rolling chassis that runs {and sounds pretty good}. Had a pretty good mp3 file but won't work here.
I was little worried about the idle quality based on what I was told about the cam selection but...
Chassis with Cab pix.
We are now in the process of body work and finding replacement parts. This is where the real work begins (not that it hasn't been fun thus far).
With a year of work behind us, it has been very much of a learning experience so far. I am sure the learning is just beginning... I hope to have a drivable rig by the end of this summer?
Thanks for looking and I hope to keep this updated as we move forward.
Thad
Teardown
Bare Frame (almost)
SBC 327 so we found one from a '64. It is now 0.040 over, 9.5:1 compression, 270H comp cam, balanced, Full MSD ignition, EZ-EFI, etc.
TCI IFS
Chassis with Cab
Welcome to the " bolt ". Always great to have another Art Deco truck in our midst. I am interested in how your EFI system performs. My 327 is pretty close to yours in spec, except for the Edelbrock carb setup. When you get her on the road we will need to compare notes.
1940 Chevy KC 1/2-Ton
Bodywork??? It looks great the way it is.
Welcome to the Stovebolt. Had an Art Deco back in the mid 80's and let it get away. Yours brings back memories.....but yours, even now, looked better than mine!!!
Good work your doing.
Nice!
I like that 41-327 nice set up
1940 Chevrolet 3/4-Ton
"Project XJ-PU-V12"
More pix on Flickr
In business, words are words, explanations are explanations, promises are promises, but only performance is the true reality.
Former Workshop Owner
Very nice thumbs_up
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Red dot, center of chest ...
Man, what would be really cool is to research that decal on the door and restore it over the paint job. So you'd have a custom rod with a nostalgic reminder on the door.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
The painting on the door is from a local electrical contractor. The funny thing is I know a contractor who says his dad used drive that truck when he worked for that company... Small world.
I doubt it will get restored at this time?
Well, not much going on right now. Trying to decide on body parts... replace the cab or spend many hours fixing it? That is the question...
Well you're off to a great start. Hammer out the dents and keep her going!
NICE !!!!! Can't wait to see the final results!
Stranger
Frank in Iowa
"Mater's Cousin"
More pix in Photobucket
We now have a replacement cab, grill and running boards.
Moving forward again.
Cab is on the frame for now to test fit seats and steering...
Pictures of cab on frame...
cab on frame
cab on frame rear
Progress....
Seats, Steering Column, Steering shaft, Column Shift linkage are fitted now.
Working on floorboard and toebord now.
Will have to get updated photos posted soon.
Picture of steering column, floorboard, etc.
Picture of steering and shift linkage. Used Borgeson steering joints and Lokar 1804 shift linkage. Tight but it works...
Pictures of seats.
Seatbelts are on the horizon (have to decide what to order 1st.
Also, about to order a complete new bed from Mar-K...
steering column and floorboard
seat driver view
seat passenger view
New bed from Mark-K.
We have to push the rear wheels out about an inch on each side to get clearance. Hindsight is always 20/20...
Mar K bed!!
Finally our custom SST Fuel tank.
It has been a long time in the making. Built by us, welded by a friend.
We are also in the process of laying out the wiring. Chose a Speedway 20 Circuit Harness, it is prety much complete with everything from the fuse block, fuses, connectors, etc.
Had to rearrange the harness.
custom fuel tank
Well, it been a while since I checked in.
We got the 41 road worthy (sort of). Had an alignment done and off we went.
We have been driving it around on back roads to work out the kinks.
The engine was not performing the way we expected. After hours of revising timing, vacuum advance, EFI settings, etc. without any luck we took it to a tuning shop and had it ran on a chassis dyno so they could tune it...
A pic of how it looks on the way to the tuning/dyno shop.
Come to find out, we had missmatched some parts. The intake and cam were too big and not playing well with the rest of the engine (ie power pack heads, etc.) I can post the dyno results if anyone is interested (dissapointing of course).
We decided to make a change...
We pulled the engine and tore it down to the short block. Kind of glad we did since we found that one of the roller tip rockers had a broken pin. That was a surprise.
We changed the power pack heads, cam, lifters and intake to basically an Edlebrock #2022 Kit (whole upper end) with some minor differences and added a set of full roller rockers. It is about ready to go back in.
Hope to get it running again in a few days.
Based on the tuning guy, we should see a significant difference. Hope that is true...
We will see what happens when it hit the road again...
on way to shop
errrr
clean engine
Authorized Pest
Authorized Pest
Thad,
This is a good update to the truck. Glad to see you are making progress. Good to be posting it here. This helps folks who happen to jump in on your Gallery page to see how far you have gotten by clicking that link on the top of your truck page. This was our aim with this DITY Gallery and the links on the individual Gallery pages.
Peg
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Hey 41 327,
Nice work, I enjoyed your thread, I bought a 46 with the IFS setup about a month ago and pulled the old engine and trans but that's as far as I got and may have to sell it (dunno yet) but your thread sure makes me want to dive in and get busy again!
looking good!
1946 Chevy small block truck
1941 Chevy 3/4-Ton -- sold Sept. 2014 | "Ole Rusty" | In the Stovebolt Gallery
Time for an update...
We finished the engine revisions and got it back in. It sounds totally different that it did but it does run better than before. Due to weather and other factors, we have not been able to drive it much since getting it back together.
A pic of what the engine looks like now. We had to loose the 'vintage Chevrolet script' valve covers due to the roller rockers but it still looks good.
We are now doing the daunting task of body work (not my favorite thing...).
Working on the fenders and front end at this time. Rear fenders are next then to the doors.
Does anyone have an idea if there is a template for the shape if the top portion of the lower grille??? The top of this one is ~1" behind the lower part of the upper grille. We are working on matching them up...
Currently having the windshield frame blues... The one we have appears to be too rusted to salvage and getting it apart in the center is not working out too well either...
We will be tearing it down in the next month or so to get everything sand blasted. Then it will be time for some primer and filler...
engine
grille
front end
You've come a long way. Your hard work is looking good. Way to go.
Major fender work is about done.
To start cab repairs soon then it will be time for a teardown and sand blasting...
Looking good, nice job!
Lookin' Good!!
I like it ! Looks like a lot of the hard work is behind you.
V
VEW Offline
V Offline
Nice work Thad.
What rear are you using? Also, what is your steering column from? Did you need to do any modifications to fit it in, like shortening it? I have one from a '93 Blazer I'm thinking about using. I am also using a 700r4, so would be just fine with the column shift.
Thanks, and once again, really nice work!
~ Victor
1957 3100 - moved on
The steering column is from an 85 chevy van, the rear end and springs are from a 1993 Ford Explorer. We added a 1" adapter to each side to get the width we needed due to wide rear tires (255 70R 15).
Daunting body work task....
Well it has been 9 months of cut, patch, re-patch, weld, ect and it is now almost ready for the epoxy primer... Yea.
No pics to share this time but soon.
Looking at gaskets, seals, weather stripping, ect.
I am looking to get a few things from Steele Rubber Products and the rest from Jim Carter... Are there better sources?
....are there better resources?
You've dealt with two of the best but there are others. Sometimes it just depends on what the item is your looking for.
Congrats on your hard work. It'll surely be worth it and will last a long time.
Well, as time goes on so is the project.
Getting ready for some real paint soon.
It seems that fitting the hood so it sits sort of straight has been one of the biggest challenges.
Just hope that we can get back together just like this once it is painted.
I have to get around to updating the gallery and such...
I think we can see the light at the end of the tunnel now (just hope it is no a train...).
V
VEW Offline
V Offline
Looks nice!
I'm putting mine back together now too. Didn't do near as much body work as you've done. I had to get a "V" brace bar to help with the hood + front end assembly. It came, but it's a bit short and I'll need to modify it; maybe its for a car or some other model than a 3/4 ton.
Your truck looks really good!
~ Victor
It has been a while since I have given an update.
Replaced the cab with a different one along with the grill and running boards.
Been doing body work, seems like forever...
Getting it ready to paint.
1941 Chevy 1/2 Ton (AK) Truck Project
I hate it when computers do exactly what you tell them too...
I posted it before I was done...
Try #2:
Dash, gauges, steering column, wiring harness installed.
In the process of painting now. Some painted parts.
Fenders are done but no picture yet.
Cab and bed are next.
Then on to putting it all together.
Nice color. That color is going to look good on that style pickup. The hard work is beginning to pay off. Thanks for sharing.
I really like the choice for dash gauges, seems to set off the style of the truck. Pat
1966 Chevy C 30 1 ton truck
We are making progress getting it put together.
Front fenders and passenger door are on.
Also, had a video of the engine running (after being silent for ~2 years).
Grill, hood and adjustments are next...
Now that is some good work. Really looks nice.
More progress.
The front is almost together.
Glass will be done in the next day or so.
Getting the bed wood worked on soon (German Beech).
Hope to have it on the road soon.
that is sweet !!!!!!
1961 apache
Page 1 of 2 1 2
Moderated by  J Lucas
