3 members (Stovebolt48, 1955 1 Series, Charles in CA), 114 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
#955621 07/10/2013 12:34 PM
I have been looking around for things I am going to need to get my new project up and running. I am looking for brake parts but no one seems to have listings for them specific to the f370 or they list them as "all models". I just want to make sure I would be gettingthe corredct parts.....I have seen 3B post part numbers from old books he must have. Any help with part numbers would be appreciated. I am sure I am going to need everything from the master to the wheel cylinders. Also, Who rebuilds hydrovac systems. I saw in the tech section on how to rebuild one but I would rather leave it up to the professionals when it comes to brakes.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
try geoff here http://www.alretta.com/ i have used him for real hard to find stuff. he also can help you with the hydravac all you need is the tag number from the unit(if its still there) he hooked me up with one for my gmc 720 when i had that truck. you can also try http://www.brakeplace.com/ ask for rob anderson. he can line your existing stuff with stainless. he's done work for me when i couldnt get it from alretta.
3B Offline
Hy buggy5872, I haven't been ignoring your question, but I haven't had a lot of luck confirming/locating parts for the "56 F370 series". I believe the master cylinder o.e.m. p/n was 2265213 which was Wagner p/n FE-13066. However I can't locate that master cylinder at any of the suppliers. There are different front and rear wheel cylinders listed depending on what front axle is in the truck, and whether the truck had HydroVac, or AirPac brakes. if you could give us a casting number off of the master cylinder, and let us know if your front wheels have a single front wheel cylinder or two wheel cylinders per front wheel that may help to identify what you need to purchase, hope that helps.
3B and Shane,
I've never found a MC for any of my TF 2-1/2 ton trucks, I've always had to send them out for sleeving and then put a new kit in them.
The wheel cylinders have been on the shelf at the NAPA warehouse or my BIG turck parts house...same with the Hydrovac.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks for the help guys. Once I get it home in September, I will check and see exactly what I have and need
Shane
1959 GMC F370 LCF
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
I have a 57 GMC 370 LCF. It has 2 wheel cylinders per wheel for a total of 8. Fronts were different from rears. I never did find a master cylinder, just rebuilt it myself. Bought a NEW Hydrovac from a guy in Morris, Il. cheap as a rebuilt one. His business is Midwest Power Products, name is Rich, nice guy. The wheel cyls. and brake lines came from NAPA. After about $1000 I have great brakes!
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
I had the best luck with NAPA, they have these weird things called "books",... wink
Anyway, if I recall right I measured the bore on my the master cylinder and we found it was the same as the 1-ton trucks and they had one for me in a day. Wheel slaves depended on the truck, since mine was modified for a dump the fronts were 7/8" and I have two 2" slaves per wheel out back. I took the measurements in and they used a book to match them to later year products that were identical or at least close enough to work.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
