7 members (Donf, King Kielbasa, jmoore, Gdads51, cmayna, 2-Ton, 1 invisible),
85
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,169 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | I have been looking around for things I am going to need to get my new project up and running. I am looking for brake parts but no one seems to have listings for them specific to the f370 or they list them as "all models". I just want to make sure I would be gettingthe corredct parts.....I have seen 3B post part numbers from old books he must have. Any help with part numbers would be appreciated. I am sure I am going to need everything from the master to the wheel cylinders. Also, Who rebuilds hydrovac systems. I saw in the tech section on how to rebuild one but I would rather leave it up to the professionals when it comes to brakes. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | try geoff here http://www.alretta.com/ i have used him for real hard to find stuff. he also can help you with the hydravac all you need is the tag number from the unit(if its still there) he hooked me up with one for my gmc 720 when i had that truck. you can also try http://www.brakeplace.com/ ask for rob anderson. he can line your existing stuff with stainless. he's done work for me when i couldnt get it from alretta. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy buggy5872, I haven't been ignoring your question, but I haven't had a lot of luck confirming/locating parts for the "56 F370 series". I believe the master cylinder o.e.m. p/n was 2265213 which was Wagner p/n FE-13066. However I can't locate that master cylinder at any of the suppliers. There are different front and rear wheel cylinders listed depending on what front axle is in the truck, and whether the truck had HydroVac, or AirPac brakes. if you could give us a casting number off of the master cylinder, and let us know if your front wheels have a single front wheel cylinder or two wheel cylinders per front wheel that may help to identify what you need to purchase, hope that helps. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | 3B and Shane, I've never found a MC for any of my TF 2-1/2 ton trucks, I've always had to send them out for sleeving and then put a new kit in them. The wheel cylinders have been on the shelf at the NAPA warehouse or my BIG turck parts house...same with the Hydrovac. Mike B  | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | Thanks for the help guys. Once I get it home in September, I will check and see exactly what I have and need | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I have a 57 GMC 370 LCF. It has 2 wheel cylinders per wheel for a total of 8. Fronts were different from rears. I never did find a master cylinder, just rebuilt it myself. Bought a NEW Hydrovac from a guy in Morris, Il. cheap as a rebuilt one. His business is Midwest Power Products, name is Rich, nice guy. The wheel cyls. and brake lines came from NAPA. After about $1000 I have great brakes!
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I had the best luck with NAPA, they have these weird things called "books",...  Anyway, if I recall right I measured the bore on my the master cylinder and we found it was the same as the 1-ton trucks and they had one for me in a day. Wheel slaves depended on the truck, since mine was modified for a dump the fronts were 7/8" and I have two 2" slaves per wheel out back. I took the measurements in and they used a book to match them to later year products that were identical or at least close enough to work. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
