2 members (55shaker, ronsway),
71
Mod | | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I recently got my '46 on the road. I've replaced all the u-joints and there is little, if any slop along the drive line to the rear end. I understand that the straight cut gears in the 4 spd are supposed to make a lot of noise but mine seems quite loud. In particular I've never used it on blacktop in 4th gear. While it's quieter than 2nd and 3rd, it still howls when under load at 35-40mph. My dad remembers these trucks being loud inside and if you watch the old WWII era videos of the Chevy trucks you can hear the gear whine. I thought I'd see if this is supposed to be common or I have some bad bearings in the transmission. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | those trannies are always noisy, and considering the age [and likely abuse of a 1T hauling brick!] it certainly could be needing an overhaul, but make sure some of the sound isn't from the pinion bearing
Bill | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | They are noisy in all gears but high. There should be no transmission noise in high. Noise on the pull in high is most likely pinion bearings.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | This is the 3/4 ton I'm referring to. I had the rear open and everything looked nice and clean concerning the bearings. The noise seems to be at or under the seat. I can also feel vibrations through the steering wheel. I wouldn't think that pinion vibrations would resonate up to the front.
I did open up the short section of enclosed drive shaft behind the transmission. The U-joint there seemed pretty sloppy and wore out the brass sleeve. I put a new sleeve in but didn't mess with the u-joint since it's hard to find. Could this be the source? Maybe too tight? Also I filled this separate from the transmission with gear oil but this is still fed by the transmission oil too?
On a side note about the enclosed drive shaft, has anyone converted it to open using a modern center carrier bearing, custom shaft, and a 4spd transmission from a larger truck?
| | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | Can you update us on the noise problem in 4th gear? Your symptoms sound just like mine. More of a worn bearing sound in 4th gear. I wonder if the way the 4th is an internal gear that is pushed into the gear teeth on the input shaft makes a difference with how the input shaft rides in the bearings. In other words the power is straight through rather from coming from the gears on the counter shaft. | | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | One more thing, my needle pilot bearing between the main shaft(output) and input shaft is new. | | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | There is a link in my signature to a video as a reference to the sound of a 46, granted I have a 2 ton, its the same 4 speed transmission. There is plenty of gear whine in 1st through 3rd. 4th is pretty quiet. Any whine you can hear in the video with the 4 speed in 4th is the auxiliary transmission, it whines in both under-drive and overdrive. Next time I have a load and remember the camera, I'll capture what it sounds like working, no load in the video. The whine in 2nd and 3rd loaded to the weight rating and pulling a hill is like nothing else.
The whine however, does not induce vibration that can be felt anywhere in the truck. Sounds like that sloppy u-joint could be a contributing factor, but I'm not that familiar with the enclosed driveline trucks. | | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | Some more info on the 4th gear noise.
I have a 1946 GMC 1.5 ton. Standard 4 speed, no power take off of any kind. U joints are new. Drive shaft is open type. Center propeller bearing is smooth, tight, and rubber propeller bearing cushion new.
I test drove the truck again to listen carefully. The sound always goes away when I depress the clutch pedal. This might be more of a higher RPM that creates this noise. Sometimes Under light load or no / little acceleration I can make the noise go away in 4th gear. This weekend I'll check the clutch throughout bearing in case it's spinning a higher RPM's. I'll also pull the top of the transmission case and look at the 4th gear again for wear. It looked fine the last time was working on my transmission. What should I be looking for with the gear spacers? Is there a tolerance spec?
My dual performance differential has a fair amount of gear lash in the pinion, almost a 1/16" but it runs good with no noise that from the rear of the truck. Pilot bearing at the crank is new too.
mjl
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Considering the backlash between the ring and pinion should be .008"-.010" on most, I think your .062" is giving you more noise than you think. And yes, those small cab trucks really reverb any noise.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I agree with Dave, .062 is too much lash and those gear will sing like a church choir.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | Thanks I'll start another topic on this as I highjacked this thread. | | | | | Joined: Oct 2012 Posts: 60 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 60 | Update on 4th gear only noise. It was caused by a worn forward roller bearing on the counter shaft. I found a used transmission at the Iola car show in Wisconsin and it was about the same cost as bearings. Installed new trany and noise gone and truck now shifts with little grinding. Happy camper. | | |
