| | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Removed hood to paint the inside and its components. When removing the 3 bolts on each side there was what looked like pipe dope in the threads. I am assuming at some point in this trucks life this was added to hold them in place as I don't see any reference to it in the shop manual. Has anyone else found this as well? If I need to add some it will be much easier to do it now before its back on the truck. Thanks Steve | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it may be a sealer someone added where they thought they might have a leak or, more likely, it's something like Never-Seez someone added to prevent corrosion
Bill | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If it's pipe dope it won't hold the bolts in place, it will keep them from seizing. It was probably added at some point along the lines. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have found that material on hood bolts on my trucks. I like Bill's suggestion that this was a leak-stop sealer. Maybe this is shown in the Factory Assembly Manual?
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I feel my 52 was original and it had some "black putty" type stuff where the bolts go through. In my OPINION it is there as a sealer. I've seen this same black putty many times where there were body holes with bolts and potentially could let water in. When I put my hood hinges back on I rolled me up a strip of the 3M black weather stripping stuff, into a ball, and put it back in.
| | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | thanks everyone for the input, much apreciated!
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just like redlegs says, GM put Dum-dum (body seam sealer) behind the hinge to keep water from leaking into the interior of the cab. Common to all of the AD's. Just get some from you local body shop supply or FLAPS and apply it generously around the bolt holes before you bolt the hinges back on the cowl.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
