7 members (tclederman, Hotrod Lincoln, klhansen, UtahYork, Leo, Goach2, 1 invisible),
137
Mod | | | Forums66 Topics128,185 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | my bed is original to 1953 chevy 3100. But it showed no sign of the side angle being welded.
Smooth as a evening lake.
Did some of these beds not have angle strips on the side? | | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | For a '53 I don't think so. Every one I've seen in the last 40 years had the side bed angles.
If they have been removed you would probably see grind marks or rust pits where they originally were. Has the bed been rebuilt and repainted? Maybe someone cut them off and smoothed things out.
Paul | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | yes possibly - it was primed when I got it- no wood bed - I took it back down to bare metal - but saw no sign of weld/grind marks
I am glad I did not weld them on for 3/4 inch boards- as the supplier I got the oak from sent 1/2 thick boards. I do not plan on using the bed as a work truck so I guess I will use these "Dress up" thin boards | | |
