3 members (TUTS 59, Hugh63c10, Phak1), 212 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
#955193 07/08/2013 6:31 PM
I have removed the doors from my '37 pickup getting ready to clean, paint, etc. It appears that there was a horizontal window wipe strip at the bottom of the window with the wipe strip pressed into the door. Does anyone know where I can obtain this strip. It looks like it is a press in fit, but I am hesitant to pry out the old until I know if it can be replaced.
Also, any recommendations on the window channel felt as to what type is best?
Thank you all,
CAB
I got my wiper from JimCarter. I imagine he still carries it...and the window channel.
http://www.oldchevytrucks.com/
click on the years that cover your truck and then click on the window items.
If its like my 46 the channel in the door and inside door panel accepts a rubber strip. You have to crimp the strip into the channel tohold it.The window felt channel and rubber strip are available from most of the old chevy parts houses.
look at steel rubber .a little high but every thing i have ever bought from them has fit real good
Hi - just replaced them on my 37. Jim Carter sells them (under side window items) - one goes on the inner door and one on the outer door. It is a press fit but I used 3m weather strip adhesive as well to hold it in there.
There were a lot of rubber pieces on those doors to replace and Jim Carter sells all of them!
Moderated by  ndkid275, Phak1
