1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 29 New Guy | | New Guy Joined: Aug 2000 Posts: 29 | I have removed the doors from my '37 pickup getting ready to clean, paint, etc. It appears that there was a horizontal window wipe strip at the bottom of the window with the wipe strip pressed into the door. Does anyone know where I can obtain this strip. It looks like it is a press in fit, but I am hesitant to pry out the old until I know if it can be replaced. Also, any recommendations on the window channel felt as to what type is best?
Thank you all,
CAB | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I got my wiper from JimCarter. I imagine he still carries it...and the window channel. http://www.oldchevytrucks.com/click on the years that cover your truck and then click on the window items.
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | If its like my 46 the channel in the door and inside door panel accepts a rubber strip. You have to crimp the strip into the channel tohold it.The window felt channel and rubber strip are available from most of the old chevy parts houses. | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | look at steel rubber .a little high but every thing i have ever bought from them has fit real good | | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Hi - just replaced them on my 37. Jim Carter sells them (under side window items) - one goes on the inner door and one on the outer door. It is a press fit but I used 3m weather strip adhesive as well to hold it in there. There were a lot of rubber pieces on those doors to replace and Jim Carter sells all of them! | | |
