6 members (Gdads51, Forty9, Rusted Nut, 39Master85, BC59, 1 invisible), 94 guests, and 1 robot.
Topics128,132
Posts1,056,376
Members48,441
#955079 07/08/2013 9:39 AM
I finally started my '41 GMC on Friday after sitting for three years. After unsticking the float needle, all is fine. I drove it about ten miles and turned around on as asphalt driveway. One rear tire dropped off the pavement about 6 inches. When I eased forward, I heard a terrible popping sound. I stopped immediately and looked underneath. Seeing nothing out of the ordinary, I inched it forward again...and still had the popping sound. I put it in reverse and it did not pop. After several forward and backward moves, it made one popping sound and I felt whatever was in a bind free up. It has given me no problems since. Does anyone have any idea what might have been going on? Thanks, Jim.
Need to do a visual inspection inside differential, pop the cover rotate gears. I'd jack it up and see if you can rotate wheels etc.
Best of luck
1946 1/2-Ton Chevy
Maybe it was the torque tube ball on the back of the transmission. Possibly froze up from sitting so long??
1949 Chevy 6400
1931 Chevy Firetruck
ODSS Lawman
ODSS Lawman
With all these unknowns, opening the rear cover is the first step. There could be something inside like water, low oil, or debris that can cause noise. Also the gears, bearings could have an issue.
Best bet is to open it up and see what you have.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
