1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95476 04/27/2006 11:09 PM | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Has anyone used this and if so can anyone give me a lot of tips. I comes with instructions and all the wires are numbered but it makes no sense. There idea of instructions are more of a generic key for the numbers on the wires. In short I have no idea what I am doing and it is pretty frustrating.
Thanks Brian
1946 1/2 ton I'm not addicted I just don't know when to stop
#95477 04/28/2006 1:41 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | With some help from many others on this site I have just completed most of the wiring on my ’41 with a home made harness. If you have specific questions maybe I can help Also if you go to this web site you will find a good wiring diagram. http://chevy.tocmp.com/chevywiring/index.htm | | |
#95478 04/28/2006 3:13 AM | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Kip, I may just be emailing you for advice but what I am really looking for is any advice specific to the Jim Carter wiring harness. They just haven't giving me much to work with. Brian
#95479 04/28/2006 4:10 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I'm doing the same as Kip's41... I am rewiring things myself with spools of wire. Since what we're doing is similar to what you're doing (only we don't have the diagram or the numbers) I think that we can help you out. Alan Horvath might pop in (he's one of the moderators) and throw in his two cents. He's done a harness kit rewire job and may be more helpful to your specific frustrations than Kip or I. He's got a write up that might interest you. It can be found here If you have some specific questions (e.g. "I have a six gauge wire. Where does it go?") Kip and I can probably help you out. | | |
#95480 05/01/2006 2:37 AM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | the numbers should let you ID each end of the same wire. Did you try to lay out the harness the wires my fall into enough of a location to help figure it out. you should have a wiring diagram to help figure it also.
"It ain't a truck if you can't hose out the cab."
#95481 05/20/2006 10:14 PM | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Well thank you all for all your help. I took another look at the harness that I had and it turns out it was for an alternator not set up for a gen. Once I figured this out and got the right one it was a piece of cake. By the way I spoke with Julie at Jim Carter she set me up with a return authorization number and reorder the correct item. She was great help. Thanks again for everyones help. Brian
#95482 05/21/2006 3:34 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | You're welcome. I'm glad everything worked out for you!
Julie is a swell lady, isn't she? She helped me out once, too. | | |
