1 members (JW51), 137 guests, and 2 robots.
Topics128,049
Posts1,055,741
#95452 04/22/2006 6:46 PM
Apprentice
Apprentice
I need to rewire my 65. Problem is, it is also my only source of transportation. Would it be possible to buy a new fuse block and attach it to vehicle. Then while the old fuse box remains, slowlwy over a period of a few months (on weekends) rewire each circuit to new fuse box with new wiring. Has anyone done this? Is it feasable? All comments welcome.
#95453 04/22/2006 9:00 PM
Scruffdawg,
I just finished re-wiring my '63 and I can't imagine trying to do it the way you are talking about. This of course assumes my limited abilities, but one of the first things I did was rip out all of my old wiring to keep from getting confused. I suppose that it is possible...better you than me! If it were me I'd try to find alternate transportation while the re-wire was in progress.
Daily Driver 63 C-10 LWB Fleetside
#95454 04/24/2006 10:36 PM
I wouldn't try it if I were you! My own experience with re-wiring (mainly on Harleys I admit) has taught me that it needs to be done in as orderly a fashion as humanly possible, othwerwise things get forgotten, lost or broken.
Plus you risk damaging the new stuff by running it with the old.
63 GMC Fleetside; overbuilt, over-thirsty and over here!
#95455 04/24/2006 11:36 PM
1 Offline
You can do it but it will be more of a rats nest then you would whant. all you need to do is run on || with eachothere one thing I would do if it is the way you need to go is go to home depot and get some 3M high vis. elec tap and tap all old wire befor you even start(maby agt both ends) this will make it easy to refrance. what I would do if you could take and do a long weekend and just doit.
#95456 05/01/2006 1:37 PM
Check out my Rewiring Checklist before you begin: Here
Then, if I were you, I'd take a long weekend or a week's vacation and do the whole thing. You have fun ... and when it's finished, you'll feel like a million bucks!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#95457 05/20/2006 11:59 PM
I forget who the supplier is off hand, but there is a direct plug & go wire harness for the '60-66 trucks. This could be done in 1 day, maybe 2.
I believe it's in the Classic Trucks magazine if I remember correctly.
I've rewired my '62 (from scratch) over 1 weekend, the first day was the cab, second day was under the hood, headlights, and taillights.
I did this with the help of the shop manuals (supplements 1&2)
David
My truck don't leak oil, it just marks its teritory.
#95458 05/30/2006 11:41 PM
I bought an ez wiring harness for $165 and installed it in my 62 in 10 hours, and everything worked!!!!!!!!!
1961 k-10
86 c-20
02 duramax
