0 members (),
361
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95371 04/16/2006 6:43 AM | Joined: May 2001 Posts: 49 Member | | Member Joined: May 2001 Posts: 49 | Okay, y'all are probably tired of hearing about '41 horns, but I've got another question. First off, many thanks to everyone for the info on hooking up the horn. Finally got mine working today. Couldn't figure out how the button worked until it was explained how it's actually the cone shaped unit that does the job. Had to adjust the steering shaft cover so there's some play between it and the cone unit, then I put the spring and horn button on and wa-laa, it works!
I converted my truck to 12 volts. The horn seems to work fine on 12 volts, but I'm worried about burning it out. So I installed a medium resistor (one recommended for the ignition system) and the horn didn't work. Tried a light resistor (for the gas gauge) with the same result. So its back to being hooked up to 12 volts and it works fine. Is it okay to run it on 12 volts or will it burn out after awhile? Bear in mind that this is Southern California where we use our horns a lot.
Charlie
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
#95372 04/16/2006 10:14 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | as long as you aren't holding the horn button down for too long,it should be fine. It's louder on 12 volts too,isn't it? That's a good thing. Speed | | |
#95373 04/16/2006 3:13 PM | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Speed is correct. Under normal use you'll never hurt your horn. When I was a kid my dad would go to the salvage yard to buy 6 volt horns & put them on our family cars (12 volt). Dad liked LOUD horns.
#95374 04/16/2006 3:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ll bet you have some burned out resisters. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95375 04/17/2006 6:48 AM | Joined: May 2001 Posts: 49 Member | | Member Joined: May 2001 Posts: 49 | Thanks for the advice, guys. I'll keep 'er at 12 volts and take it easy on blowing it. The horn wasn't hooked up when I got the truck, so I don't know what it sounded like at 6 volts. But it is plenty loud now. Also got a spare horn just in case. And the resistors I tried were new, but never tested so maybe they're bad. I'll check 'em out later.
Charlie
#95376 04/20/2006 10:20 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | 12 volts will push a lot more amps through that horn. normal horn use will not hurt it. You should use a relay to avoid burning the horn button contacts.
"It ain't a truck if you can't hose out the cab."
#95377 04/23/2006 1:43 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | just had to talk about the horn!!!!!!!!!!!! mine just gave up after 23 yrs of 12 volts. i would push the button and the engine would shut of until i let up on the button. the relay is burned up. will have to get another one the first if the week. thanks again. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#95378 04/23/2006 9:15 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | OLD; Sorry if we jinxed ya... Speed  | | |
#95379 04/23/2006 7:56 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | why don't you just buy a fiamm horn set they are loud and about $10-16 bucks 12 V http://motors.search.ebay.com/fiamm...QfsopZ1QQsacatZ6000QQsamcmZ6000QQsaspiZ2
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#95380 04/24/2006 11:57 PM | Joined: Jan 2006 Posts: 55 Member | | Member Joined: Jan 2006 Posts: 55 | if you would are wored you can use OHM's Law the first step is it find the resistance of the horm DMM or if you you shold be able to find specs on a shop manule that will give you the ma pull of the horn. if you do not have a DMM but can find the amoeres pull simply use this formula to find resistand R = 6/I (I= Current in AMPS and you are using 6 for 6 volts) then wen you have the Resistance cunect a res. with the same R value in seareas. then your hore will get just 6V and the corect I to it. | | |
#95381 04/26/2006 9:29 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i replaced the relay with a 12 volt one, evidently that was not the only problem. it caught the relay on fire and also the wiring on the fender started to smolder. there was a short there. i still worry but i think everything is ok now. i tightened the wiring on the fender and no more smoke. Ron
#95382 05/23/2006 6:21 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 1947rbt is right. All you have to do is find another resistor and wire it in series with your horn. FYI Your spare horn will act as that resister. Instead of just crating heat and magnitism you could be creating more noise! | | |
