1 members (Wooley), 105 guests, and 0 robots.
Topics128,151
Posts1,056,997
Members48,460
#95371 04/16/2006 6:43 AM
Okay, y'all are probably tired of hearing about '41 horns, but I've got another question. First off, many thanks to everyone for the info on hooking up the horn. Finally got mine working today. Couldn't figure out how the button worked until it was explained how it's actually the cone shaped unit that does the job. Had to adjust the steering shaft cover so there's some play between it and the cone unit, then I put the spring and horn button on and wa-laa, it works!
I converted my truck to 12 volts. The horn seems to work fine on 12 volts, but I'm worried about burning it out. So I installed a medium resistor (one recommended for the ignition system) and the horn didn't work. Tried a light resistor (for the gas gauge) with the same result. So its back to being hooked up to 12 volts and it works fine. Is it okay to run it on 12 volts or will it burn out after awhile? Bear in mind that this is Southern California where we use our horns a lot.
Charlie
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
as long as you aren't holding the horn button down for too long,it should be fine. It's louder on 12 volts too,isn't it? That's a good thing.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Ex Hall Monitor
Ex Hall Monitor
Speed is correct. Under normal use you'll never hurt your horn. When I was a kid my dad would go to the salvage yard to buy 6 volt horns & put them on our family cars (12 volt). Dad liked LOUD horns. grin
Riding in the Passing Lane
I,ll bet you have some burned out resisters.
1972 Chevy c10 Cheyenne Super
Thanks for the advice, guys. I'll keep 'er at 12 volts and take it easy on blowing it. The horn wasn't hooked up when I got the truck, so I don't know what it sounded like at 6 volts. But it is plenty loud now. Also got a spare horn just in case. And the resistors I tried were new, but never tested so maybe they're bad. I'll check 'em out later.
Charlie
12 volts will push a lot more amps through that horn. normal horn use will not hurt it. You should use a relay to avoid burning the horn button contacts.
"It ain't a truck if you can't hose out the cab."
just had to talk about the horn!!!!!!!!!!!! mine just gave up after 23 yrs of 12 volts. i would push the button and the engine would shut of until i let up on the button. the relay is burned up. will have to get another one the first if the week. thanks again. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
OLD;
Sorry if we jinxed ya...
Speed wink
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
why don't you just buy a fiamm horn set
they are loud and about $10-16 bucks
12 V
http://motors.search.ebay.com/fiamm...QfsopZ1QQsacatZ6000QQsamcmZ6000QQsaspiZ2
Jim & Caroline
1 Offline
if you would are wored you can use OHM's Law the first step is it find the resistance of the horm DMM or if you you shold be able to find specs on a shop manule that will give you the ma pull of the horn. if you do not have a DMM but can find the amoeres pull simply use this formula to find resistand R = 6/I (I= Current in AMPS and you are using 6 for 6 volts) then wen you have the Resistance cunect a res. with the same R value in seareas. then your hore will get just 6V and the corect I to it.
i replaced the relay with a 12 volt one, evidently that was not the only problem. it caught the relay on fire and also the wiring on the fender started to smolder. there was a short there. i still worry but i think everything is ok now. i tightened the wiring on the fender and no more smoke. Ron
2017 Buick Encore
See more pix
1947rbt is right. All you have to do is find another resistor and wire it in series with your horn. FYI Your spare horn will act as that resister. Instead of just crating heat and magnitism you could be creating more noise!
