2 members (Hotrod Lincoln, TexasA&M48Truck), 186 guests, and 1 robot.
Topics128,082
Posts1,055,964
Members48,430
#952614 06/25/2013 8:05 PM
Have a new wiring harness from jc's for 41 1/2 ton. Instructions say that dimmer switch, brake lights, parking lights, tail lights and the voltage regulator BAT wires all get hooked to headlight switch.
The original wiring diagram show the volt regulator BAT wire going to ammeter - the ignition and light switches hook up here too.
What should I do? Besides hang myself with this harness. Should I lengthen the volt regulator BAT wire and run it to the ammeter and run a new wire from the headlight switch to the ammeter too?
The harness also has an unlisted wire in it as we'll as wires with the wrong listed color... Thanks, joe
using the BATT terminal on the switch for a junction works as well as using the terminal on the ammeter, they probably are working from a different diagram or just trying to keep the ammeter connections clean and simple - if the wire length works best, do it the way they say, which should still have a wire from the switch to the ammeter - the volts still go to and from the same place [the battery], doesn't matter which route they go to get there
That's the odd thing. The only wire to the ammeter is from the starter. The other post on the ammeter is empty.
well then they did make a mistake, you wouldn't have a functioning ammeter, so you'll need to add a wire to the other post of the ammeter, either moving the reg wire from the sw or adding one from the sw to the ammeter - and you should inform JC and the harness maker of the mistake
I had the same wire missing when I did my '46. I made one up from wire and terminals I had around and threw it in there from the ammeter to the light switch. All works well now.
Ed, your ignition and horn wires ran to the ammeter as they were originally supposed to?
watsjoe #953405 06/28/2013 11:10 PM
I believe so. It's been a while since I did the wiring. I know the wire from the ammeter to the light switch was missing, several wires were the wrong colors (as per included instructions) and I think the horn wire was completely mislabeled. Checking wires against the diagram in the manual helped a lot with figuring things out.
watsjoe #953408 06/28/2013 11:40 PM
Joe,
Take a look at the original wiring diagram, it should help you "see the light"
http://chevy.oldcarmanualproject.com/electrical/wiring/pdf/46truck.pdf
Harold
chug
Harold
