8 members (Perro, Hush, Lightholder's Dad, John L., Otto Skorzeny, lumbersawyer, FAST55, Hanks custodian),
182
Mod | | | Forums66 Topics128,075 Posts1,056,007 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95166 03/21/2006 7:43 AM | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Last night on the way to work I started my Apache and I let her warm up for about 15 min. in the driveway. I walked out and the motor was off. My neighbor said he heard a back-fire and the engine stopped. I looked at the spark wires all ok. the battery and starter all good,(the key was on) and I looked at the distr. no moisture in the housing Rotor looks good but,I could not check for spark. P.S. there is fuel,and the carb.is good. What am I forgetting?
Cliff(drove my 54 Plymouth to work)59 | | |
#95167 03/21/2006 2:04 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | It requires four things to run
1) fuel
2) compression
3) spark
4) the first three must be timed properly
Usually a backfire means something is out of time (firing with a valve open) or too richly fueled. | | |
#95168 03/22/2006 4:36 AM | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | Thanks Inky I started with the points,condenser, and rotor but Now I will start looking at wires and plugs. tomorrow I will examine the timing.
Will return If I can't get her going in the AM.
regards
Cliff59 | | |
#95169 03/23/2006 9:44 AM | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | She works great now (needed new points)
thanks Inky
Cliff59 | | |
#95170 03/23/2006 1:30 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Good for you!  Glad you're back on the road!  | | |
